Old 09-24-2013, 12:05 PM   #1
ugotd8
68 Steering Column strangeness - advice needed
Good morning all. So I picked up this '68 C10 yesterday and found that the PO installed the steering column rotated:
Opening the hood I discovered why, he did it to allow the shift arm to clear the booster:
So, questions I have are:
Anyone have an idea what MC/booster this is ? (I'm thinking 73-87 truck?)
Ideas on how to fix ? I saw the thread in the FAQ on shortening the column, which I think might solve this but opens other cans 'o worms.
My 3D Gallery
ugotd8 is offline   Reply With Quote
Old 09-24-2013, 12:26 PM   #2
Mister-B
Re: 68 Steering Column strangeness - advice needed
Yeah, that looks like a much newer booster. The correct booster would look more like this
I don't know how to fix your steering column, other than installing the correct booster
Mister-B is offline   Reply With Quote
Old 09-24-2013, 12:37 PM   #3
alsriv2
alsriv2's Avatar
Location: Formerly MD and San Diego, now loving life in Arizona
Interesting issue. Wonder what other tricks the PO had up his sleeve?
Inspect your truck fully to ensure there are no hidden safety issues.
Alan
2012 Ram 3500 Dually Crew Cab 6.7 Cummins
2014 Palomino Columbus 340RK 5th wheel
'69 Chevy C10 396BB
alsriv2 is offline   Reply With Quote
Old 09-25-2013, 09:25 AM   #4
Katrina/10
Katrina/10's Avatar
Never seen anyone do that before, an interesting solution, but not a really good idea. The master cylinder looks like one from an 81 or later model, you might be able to put some spacers between it and the firewall.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 09-25-2013, 09:44 AM   #5
BrianG
BrianG's Avatar
From what I remember, it looks a lot like the one on my 2001 Sierra. I could be wrong though, I'd have to go pop the hood and check for sure.
BrianG is offline   Reply With Quote
Old 09-25-2013, 09:47 AM   #6
VroomVroom68
Attachment 1155289
Attachment 1155290
Attachment 1155291
Attachment 1155292
Whaaaat? That's insane, I've never seen anyone do something like that...
VroomVroom68 is offline   Reply With Quote
Old 09-25-2013, 10:55 AM   #7
ugotd8
Thanks for the replies all. Yes, the PO had a few more tricks up his sleeve. There is a push button starter switch where the lighter should be.
The truck steers and stops fine, but as you can tell from the pic sometimes the shifter will bind and it's tough to find reverse.
@Katrina/10, I'm liking the idea of spacers between the booster and firewall. I assume it would just possibly need a slightly longer rod from the pedal to the booster?
My 3D Gallery
Old 09-25-2013, 11:23 AM   #8
geezer#99
geezer#99's Avatar
Why don't you just move the column down enough to clear. The shaft between the end of the column and the steering box is collapsible.
Old 09-25-2013, 11:58 AM   #9
ugotd8
Seriously considering it. Good instructions here on the board.
My 3D Gallery
Old 09-25-2013, 12:50 PM   #10
BrianG
BrianG's Avatar
I can't tell from the pic how close your booster is to the firewall, but if it were original (or even the right type of replacement), it would be spaced away from the firewall. Yes that might mean that you would need a longer rod, but check, the PO might have put in an adjustable one.
Old 09-25-2013, 12:59 PM   #11
jaros44sr
jaros44sr's Avatar
Couldnt you just put the correct OEM booster and M/C on your truck, their not that expensive
Or a smaller diameter booster
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 09-25-2013, 01:48 PM   #12
Katrina/10
Katrina/10's Avatar
The internal rod between the pedal and booster is adjustable, but I am not sure how much. You may have to extend it to get the booster far enough from the linkage. I put a booster from an 84 suburban on my truck, but it was the smaller smooth one. It barely cleared the shift linkage, so I put a dent in the back side of it with a hammer, seems to work fine.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
