Old 09-24-2013, 02:20 PM   #1
PipsC10
PipsC10's Avatar
burned 67
I found this picture while searching the web for pictures of the Rim Fire damage. For those not familiar with the Rim Fire, it is the 3rd largest fire in California history that burned a large portion of the Stanislaus National Forest in Tuolumne County. I helped with evacuations when the fire jumped containment lines on the 3rd day and it burned several homes where I was at. Trucks can be replaced, thankfully no people were hurt. The second picture is when I drove up to the fire to help evacuate.
1970 2wd short/fleet 350/350 Project "iced green dream" http://67-72chevytrucks.com/vboard/s...d.php?t=272702
2006 Toyota Tacoma double cab 4x4
PipsC10 is offline   Reply With Quote
Old 09-24-2013, 02:23 PM   #2
Saclandman
Saclandman's Avatar
Re: burned 67
Looks like it was pretty clean and straight before the fire. Sad.
Rich J.
1967 Chevy C20 Longbed Stepside w/283 and 4spdSOLD
2002 Chevy Tahoe 4X4 5.3L SOLD
2015 Chevy Silverado Crew 4X4 5.3L
Saclandman is offline   Reply With Quote
Old 09-24-2013, 04:31 PM   #3
In The Ten Ring
Re: burned 67
Could the body panels still be used?
In The Ten Ring is offline   Reply With Quote
Old 09-24-2013, 04:38 PM   #4
JointTech
JointTech's Avatar
Re: burned 67
its already heat tempered. probably bullet proof now...
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 09-24-2013, 05:29 PM   #5
LONGHAIR
Re: burned 67
You can't use sheetmetal that has been in a fire.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 09-24-2013, 08:39 PM   #6
quick60
quick60's Avatar
Re: burned 67
Actually dosent look that bad. fire may have been so fast moving it did not burn that bad. the steering wheel still intact is a good sign still has white paint on the bumper and grill trim. Might be restorable.
quick60 is offline   Reply With Quote
Old 09-24-2013, 08:54 PM   #7
In The Ten Ring
Re: burned 67
"Ya, I got my hood off a truck that was in a neighborhood-wide fire."
That would be rather interesting.
Old 09-24-2013, 10:05 PM   #8
'68OrangeSunshine
'68OrangeSunshine's Avatar
Re: burned 67
What kind of temperature regime would blow out the Windshield, rear window and door glass?
Old 09-25-2013, 07:01 AM   #9
MARKDTN
Re: burned 67
Curious as to why? If you soda blasted both sides?
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 09-25-2013, 09:00 AM   #10
Lattimer
Lattimer's Avatar
Re: burned 67
After steel goes through a fire, it generally warps all to hell and becomes brittle. It will also rust more easily due to crystalline structure changes on the surface.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 09-25-2013, 03:47 PM   #11
C0UCH
Re: burned 67
"natural patina"
C0UCH is offline   Reply With Quote
