bed parts
Hey Guys
This is my 66. I am going to put a wood bed in .Any advice on how to fix the rotted angle brackets on the sides of the bed,or does that come with the kit when you buy it. also i am missing all the cross sills what do those attach to when I get them. Sorry as you can see I am new to this any help is appreciated |
Re: bed parts
1936 Chevrolet 1/2t 1964 Chevrolet C10 1964 Chevrolet C10 (sons) 1965 Chevrolet K10 Suburban 1969 Chevrolet C10 1937 Plymouth P4 |
Re: bed parts
The rotten angle strips need to be ordered separately from mar-k. If they are rusty and full of holes and will not support the bed than new ones need to be welded in after you cut the spot welds that hold the old ones. Or I have seen people that can't weld blot them to the sides of the bed. Or if yours just look bad mar-k sells strips that you can use to cover the old ones up with. 4 of the cross sills attach to the frame and also to the strips with bolts that go in between the wood. A couple of the cross 2 of the cross sills only attach to the bed and there is one row of bolts that does not attach to the any sill. It just has large washers that hold them to the bottom of the wood (at least that is how it is on my step side). If you go to the mar-k web sight or order there catalog they have tuns of diagrams and how-to's. Also do a search on this sight. I know that angle strips have been discussed before
Re: bed parts
real pain in the rear to remove the angle strips. i used a sawsaw and made pretty quick work of them.....they have alot of spotwelds on them. i rebolted mine in since they were polished stainless steel
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
Re: bed parts
thanks guys i found the website and they have everything i need. once again this forum has come through
Moderator
![]() Join Date: Dec 2012
Re: bed parts
