LS and Turbo?
Seen some pretty mild LS engines making good HP with gm heads and some running turbos that made insane power. Friend of mine does a lot with the LS and I got to talking to him and couldn't really believe the power you can get without breaking the bank. I know what I got in my 434 and I guess I'm old school, but I got to thinking about a 6.0, maybe with a blow through carb and a turbo in my 51 chev trk. It'd be pretty impressive, I could run a 3.42 or so gear, and it'd fly but still be real streetable. I'm just thinking out loud here, but I might have to do a little research. It would look neat though when you raised the hood!
Re: LS and Turbo?
why a carb? fi makes more easier..
-'73 c/10 - Low with Go - will be complete... probably never. -'90 2wd Blazer - well... soon enough anyways. -'84 SWB - the daily gas guzzler. |
Re: LS and Turbo?
Thought about that too, was going to price bigger injectors, and whatever else I'm going to need.
Re: LS and Turbo?
I found out that what number you have in your head cost wise, you will need to double it...lol
http://67-72chevytrucks.com/vboard/s...d.php?t=494388 431 big block times, changed to a 6.0 ls with turbo 1.58- 60' 7.18- 1/8th mile@95.18 11.37- 1/4 @115.81 |
Re: LS and Turbo?
I usually figure extra on anything, the chevelle took the extra and then some. I do everything myself so that helps. If you could just prevent that "while I'm at it I might as well change this" I'd be in better shape moneywise.
Re: LS and Turbo?
VHT look over on the Houstonperformancetrucks.com website lots of LS turbo guys over there.
'72 SWB 3,600# Indigo Blue , Sunset Racing Pump Gas 582" 1,002hp / 833tq ,Transking 400 W/ Transbrake, Moser Dana 60 w/4.30 Old Motor: 60'. 1.43 1/8 6.58@104.64 1/4. 10.42@127.10 Nitrous: 60'. 1.28 1/8. 6.15@ 112.02 1/4. 9.75@ 136.32 |
| Bookmarks |
