Old 09-25-2013, 12:52 PM   #1
runningiron
runningiron's Avatar
Lowered shock parts numbers?
I have a 1966 C-10 stepside shortbed. I found some like new 2" lowered springs for the front and 3" lowered springs for the rear. The truck will just be used as a daily driver and I won't be hauling anything heavy. Also I was thinking about using some 1 1/2" blocks in the rear with the 3" lowered springs. What shocks and part numbers would you recommend. This is a budget build, any problems to look out for. Thanks.
runningiron is offline   Reply With Quote
Old 09-25-2013, 07:05 PM   #2
gofastnut
gofastnut's Avatar
Re: Lowered shock parts numbers?
Monroe rear part number 555003 2.5" shorter than stock
still working on the front...
Jeff
96 C3500 Crew Cab Long bed (Waiting on Cool Name)
64 C-10 shortie stepside, "Ole Brownie"
C-10 Club
My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345
gofastnut is offline   Reply With Quote
Old 09-25-2013, 07:12 PM   #3
runningiron
Thanks Jeff. I've used Monroe shocks forever so I'm partial to them.
Old 09-25-2013, 07:31 PM   #4
gofastnut
gofastnut's Avatar
No problem Iron, it's slow at work right now!
The stock rear is 12" compressed 19.5" extended 7.5" travel
555003 (motorhome) is 9.625" compressed 14.75" extended 5.125" travel
Potential problem is the mounting hardware is different, (P411 vs P1221) and I don't have an idea of whether or not that part will work.
I can't seem to find a shorter shock for the front. I remember something about guys relocating their upper mounts higher on the frame. Maybe someone can chime in.
Sorry, don't have a KYB book!
Jeff
C-10 Club
Old 09-25-2013, 07:37 PM   #5
runningiron
Thanks again.
Old 09-25-2013, 07:47 PM   #6
BMERDOC
BMERDOC's Avatar
Front:
KYB GR-2 Drop Shock (344068)
Monroe 33033
KYB EXCEL-G 344072
KYB GAS-A-JUST KG5409
KYB MONOMAX 565032
MONROE Part # 33033
SACHS Part # 030223
Rears:
Rear KYB GR-2 Drop Shock (344055)
Monroe Matic-plus 32207
MONROE Part # 37098
GABRIEL Part # 71637
SACHS Part # 030752
MONROE Part # 59017
These are the numbers I have from my research.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 09-25-2013, 07:58 PM   #7
gofastnut
gofastnut's Avatar
Hey BMERDOC,
Thanks for the info, but the Monroe 33033 is a stock shock. Not sure about the other numbers. At 10.125" compressed, it's already kinda short. Guess not short enough.
Jeff
C-10 Club
Old 09-25-2013, 08:48 PM   #8
runningiron
Cool beans!!! I knew there is a plethora of knowledge out there. Thanks guys.
Old 09-25-2013, 09:02 PM   #9
BMERDOC
BMERDOC's Avatar
You're right about the front shock. It was from my records and I can't remember why I put it in there. Heres a link to a thread about KYBs. Theres more out there. I'll dig around and see what I find...
http://67-72chevytrucks.com/vboard/s...d.php?t=331653
Nick Carter
Old 09-25-2013, 09:16 PM   #10
boucher racing
boucher racing's Avatar
PLEASE READ THIS for anyone who is lowering their truck and looking for the correct shocks. I went through this process and it was a real head banger!
http://67-72chevytrucks.com/vboard/s...d.php?t=573266
happy rodding
Build Threads: "JED" 66 GMC C1000
http://inliners.org/ubbthreads/ubbth...1857#Post61857
"Cropwell" 66 C10
http://67-72chevytrucks.com/vboard/s...d.php?t=587639
boucher racing is offline   Reply With Quote
Old 09-26-2013, 04:45 PM   #11
gofastnut
gofastnut's Avatar
Hey Boucher,
Just read your link, thanks for the part number for the front!!
And, glad you got it figured out.
Jeff
C-10 Club
