09-25-2013, 03:07 PM | #1 |
Disc brake help
This is my first post ever.
Ok here's the deal.... I have a 1967 c10 with drum brakes front and rear. I'm going to convert it over to power disc on the front. I have some parts already. Parts I have is.... 72 c10 drop spindles Power brake booster 72 c10 Inner and outer tie rods and center link 72 c10 master cylinder 6 lug aftermarket rotors to fit the 72 drop spindles The parts I'm looking for is.. Brake dust shields Spindle nuts and washers Proportion valve Steel round Rotor end cap Lines to hook up the master cylinder to proportion valve and main brake lines. Brake hose or line to adapt the caliper to existing 67 line. Any help will be greatly appreciated. Part numbers and parts that interchange would be great as well. Thanks in advance. Posted via Mobile Device |
09-25-2013, 05:20 PM | #2 |
Re: Disc brake help
Anyone???
09-25-2013, 07:08 PM | #3 |
67-72 parts collector,…
Re: Disc brake help
Give these guys a call:
www.earlyclassic.com
09-25-2013, 07:16 PM | #4 | |
Re: Disc brake help
09-25-2013, 07:24 PM | #5 |
Re: Disc brake help
I have also found that the drum brake spindle "nut" will work on most drop sprindles for disc brakes.
09-26-2013, 12:41 PM | #6 |
Re: Disc brake help
Thanks for the info guys. Your awesome! One more question. Will the brake dust shields interchange from a newer truck?
09-26-2013, 01:38 PM | #7 |
Re: Disc brake help
71-87 dust shield will work fine.
