Old 09-25-2013, 03:31 PM   #1
halfadeuce
rear shocks for heavy load
I have 4 inch heavy duty drop coils from cpp on the rear of my suburban and want to drop it a little more with blocks. Are there any heavy duty shocks that I can use to keep from bottoming out when I have a load in the truck. I really want it lower but Im not sure if 2inch blocks is an option without a c-notch.
halfadeuce is offline   Reply With Quote
Old 09-25-2013, 04:20 PM   #2
vectorit
What?
vectorit's Avatar
Re: rear shocks for heavy load
Have you looked at getting just a quality set of shock absorbers, like KYB, or Bilstein, then air bags? I'd think you'd get a better ride quality out of something like that, as compared to putting in a heavy duty shock absorber with coil overs.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 09-25-2013, 04:25 PM   #3
halfadeuce
I would love to get a full set of bilsteins all around but price is an issue right now. My main concern would be not bottoming out after adding a 2inch lowering block to my current set up. Would kyb's be stiff enough to keep it from doing so?
Old 09-25-2013, 05:23 PM   #4
vectorit
What?
vectorit's Avatar
KYB Gas-adjusts are a great option, and I have run them before.
They are a gas charged shock absorber, so they are a little stiff but just right in my experience.
What kind of loads are we talking here?
A few people in the burb, bags of cement for the house projects, or towing a boat?
Chris
1968 K20 Suburban
1972 K10 LWB PU
Old 09-25-2013, 05:30 PM   #5
halfadeuce
My load is just people. I have 4 boys plus my wife and I. We've loaded up the burb to go to the beach and it only hits on very large dips. If I go 2 inches lower I'm afraid it will hit all the time.
Old 09-25-2013, 05:40 PM   #6
tlcrz1972
tlcrz1972's Avatar
KYB's are a great shock, some people complain that they are too stiff/harsh, but I really like them, especially loaded.
Thought I do suggest for carrying the load effectively you need helper air bags to carry the load, and the shocks will manage the bumbs.
Best of all they are lifetime warranty, and I know for a fact they will replace if one goes bad.
I put mine on my '72 in 1988-89 and have only had to replace one that died on me. And the ride is still the way it should be.
So back then I paid $70 plus bucks for them so they have cost me $4 to 5 buck a year.
1972 Chevrolet Cheyenne LB 1/2 ton finished restoration/rebuild 1995 350 throttle body FI, 4L6E (running on modified GM wiring harness) 3.08 posi rearend, factory A/C on 134A, p/s, p/b, late 70's power windows and locks and cruise, speakers in the dash + 6x9's behind the seat, factory tilt, 40 gallon fuel tank in the bed with integrated tool box, air assist bags on the rearend, sway bar up front and much more.
1972 chevrolet SNB finished 2002, 350 TB FI, TH400, factory A/C, p/b, p/s, (FOR SALE)
1969 Chevrolet 1 ton in work, home made PTO dump bed extended frame, 350 CI ,
1972 Chevrolet 3/4 ton suburban future project
1972 Chevrolet 3/4 ton p/u maybe a project one day
1966 Toyota Landcruiser my playtoy
tlcrz1972 is offline   Reply With Quote
