starter solenoid not working
I bought a procomp mini starter only to have it not work properly. alignment is perfect. when starting normally it just clicks, but not your typical starter solenoid click. very faint click. I metered ignition wire and have at least 12.5 volts when turning key. voltage does not drop even if keeping key turned as if starting for a while. battery is new. if I jump solenoid with screwdriver from battery lug to the small ignition wire lug...it works great. its as if the solenoid is not getting enough amperage through the ignition wire to the solenoid. I am going to swap the solenoid out with another one that I just removed from truck. so with that said the truck was running with the basic oem starter/solenoid. is this a wiring problem or just maybe a bad solenoid? I really want to use the mini starter.
Re: starter solenoid not working
i would start by cleaning and tightening all connections including your ground sides involved
just lookin and giving them a harsh stare will do nothing to help remove clean install and tighten
I will double check connections tomorrow. like I said I took a working starter off today so it at least good enough connections for the factory starter but anything is possible.
Is the starter wire (not the cable) getting a full 12 volts at the starter during start?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
Old Duffer
![]() Join Date: Mar 2003
I agree, sounds more like a ground problem than anything else.
'68 Short C20 Flatbed Dually w/ 292 4bbl, Langdon cast headers, and WC T5 trans. '81 G10 Shorty Van "Good judgement comes from experience, and a lot of that comes from bad judgement." Will Rogers "Under promise, then over achieve." |
yes Lee I checked voltage on the starter wire [not battery wire] and it maintained 12.5 volts the entire time key was in the cranking position.
is it possible that the solenoid could be sticking or possibly bad? |
I found the problem today. it was the solenoid. it would work then not work so I removed the solenoid and bench tested it with some jumper cables from battery to the solenoid . had same results. it would work then stop working all together. will I ever learn ...buying cheap ebay knock off stuff.
Glad to hear you got it figured out.
