Old 09-26-2013, 08:01 PM   #1
bigmac73
bigmac73's Avatar
vortec kickdown
I had to fabricate a kickdown bracket out of a edelbrock one, cut and weld ect ect, problem is i got it to work but set up wont let carb open all the way,
what do you guys with a vortec style manifold use for a kick down bracket with a holley DP
i could just use the shifter on the column, but i like it better on the foot control
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 09-27-2013, 05:38 AM   #2
eldogg
eldogg's Avatar
Re: vortec kickdown
I use Edelbrock #8032 throttle brackets on all my Vortec builds.
eldogg is offline   Reply With Quote
Old 09-27-2013, 07:47 AM   #3
bigmac73
bigmac73's Avatar
Re: vortec kickdown
that is the one i had to fabricate a little bit, with the holley it sets to close to the carb , so i had to re fit it and move the top section back about 2 inches, it acts like i need to move it back more to let the carb get full throttle
Mike
