Old 09-26-2013, 08:39 PM   #1
oeddieo31
oeddieo31's Avatar
Exhaust manifolds
Putting a 6.0 (I believe lsx, not for sure) into my 65 c-10. Will stock exhaust manifolds from a 2010 Camero work and will they fit between the frame rails?
oeddieo31 is offline   Reply With Quote
Old 09-26-2013, 11:41 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Exhaust manifolds
Well if its not an LS motor...then no.
Assuming its probably an lq4, the manifolds will bolt up. They are said to pretty much clear the frame rails (any manifold in this swap may require a little trimming on either the trans ear or the frame rail lip to fit and get access to all the bolt on the collector flange).
Whether or not they'll fit on your swap also depends on which motor mount setup your using, and if the engine sits for or aft of the "stock" position.
Oh, and there is no E in Camaro.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
