Old 09-26-2013, 10:38 PM   #1
eray92
eray92's Avatar
Sbc or bbc?
I have a 383(it's suppose to be) but it has ****ty 416 heads and performer intake on it. Well I wanted to buy some dart iron eagle heads and performer rpm or air gap intake so it will come alive. I could possible buy a fresh stock build 396 with a 427 cam. The motor has only been ran on the stand. I know the guy real well and he is a great guy and great mechanic. Buy the 396 or heads and cam? Truck is just a toy/daily. 200-4r 4.56s 29" tire
eray92 is offline   Reply With Quote
Old 09-27-2013, 02:11 AM   #2
andrewmp6
Re: Sbc or bbc?
Its a toss up the small block you can keep your trans,But the big block would need a new trans.If you don't care about gas mileage get the big block.
andrewmp6 is offline   Reply With Quote
Old 09-27-2013, 02:41 AM   #3
willett
Another Day, Another Dollar
willett's Avatar
Re: Sbc or bbc?
No replacement for displacement...
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 09-27-2013, 06:04 AM   #4
79Betty
79Betty's Avatar
Re: Sbc or bbc?
Go big or go home!!
When in doubt, throttle it out!
1974 Chevrolet Custom K20
2005 Ford Ranger Edge
1985 Chevrolet Custom Deluxe C10
79Betty is offline   Reply With Quote
Old 09-27-2013, 07:25 AM   #5
BigBlocksRule
Re: Sbc or bbc?
Stick with the smallblock. A 396 is the baby of big blocks and with decent heads, the 383 will smoke it. Biggest problem with the 396 is it's tiny bore - valves are too close to cylinder walls for decent breathing. If you're going to spend the coin on a big block, get a good 2-bolt 454 block, Scat cast crank and Scat rods, open chamber 781 or 049 heads, small dome pistons, and buy stock in a tire company, you'll need it.
BigBlocksRule is offline   Reply With Quote
Old 09-27-2013, 10:29 AM   #6
Rich84
Rich84's Avatar
Re: Sbc or bbc?
416 heads?? Thats whats on my 305..
Rich84 is offline   Reply With Quote
Old 09-27-2013, 12:58 PM   #7
eray92
eray92's Avatar
Re: Sbc or bbc?
Yup 416 heads , it doesn't breath good above 4000-4500.
If I got the 396 I would be getting it for the torque. Not too wirried about it being the fastest
Old 09-27-2013, 01:18 PM   #8
tucsonjwt
Re: Sbc or bbc?
If you are at all concerned with gas mileage, then forget the 396, especially one that has been hopped up. If you don't care about gas mileage, I would rather have a stock 454 out of a truck. I have had two and have run them for decades with no engine work, except for replacing the notorious "soft cam" and resulting busted pushrods on the 73 I had. In a 1/2 ton pickup a stock truck 454 engine won't use much more gas than a 350, and it has way more power and acceleration.
tucsonjwt is offline   Reply With Quote
