Old 09-27-2013, 11:41 AM   #1
65truckowner
65truckowner's Avatar
chrome center caps
I am at a loss here. I have a restored 65 chevy truck with the later model running gear under it (1983). Anyway I bought a set off allumiumn rims for it and cant find chrome center caps for this rim. It is an allumiumn modular rim with the holes around it. The center opening is 3 and 5/8 inches Does anybody have a clue where I might find the center caps this size. I have tried lmc,ebay and some other sights online.
65truckowner is offline   Reply With Quote
Old 09-27-2013, 12:17 PM   #2
79Betty
79Betty's Avatar
Re: chrome center caps
If you post some pic's it'll deffinetly help
When in doubt, throttle it out!
1974 Chevrolet Custom K20
2005 Ford Ranger Edge
1985 Chevrolet Custom Deluxe C10
79Betty is offline   Reply With Quote
Old 09-27-2013, 03:19 PM   #3
Keith Seymore
Keith Seymore's Avatar
If it is the factory forged (or cast) aluminum rim than it uses the same center caps as the rally wheel.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 09-27-2013, 05:38 PM   #4
65truckowner
Old 09-27-2013, 05:41 PM   #5
79Betty
79Betty's Avatar
Thise look like my centerlines lol. I jus got some off fleabay. Measure your inside hub hole to make sure they'll fit. They're generic ones so no markings but get the job done they're out there just search center caps
Old 09-27-2013, 06:11 PM   #6
65truckowner
That is the problem I cant find any to fit my 3 and 5/8 inch center hole.
Old 09-27-2013, 07:05 PM   #7
geezer#99
geezer#99's Avatar
THe wheels look like american racing outlaw 2's. Here's some possible caps on evilbay that come close to your measurement.
http://www.ebay.com/itm/American-Rac...8#ht_875wt_813
Or check out this guy. He could likely get you set up.
http://shop.wheelacc.com/62-outlaw-ii-c1330.aspx
Old 09-27-2013, 07:07 PM   #8
79Betty
79Betty's Avatar
How do you feel about the early 90's center caps held on by the lug nuts? Could try that route?
Old 09-27-2013, 08:06 PM   #9
Either that or if you have some rally center caps, you can drill and tap those rims and screw on the rally caps.
Also, Cprts60 had some similar wheels on his square bodies and got some hub cap clips so he could run stock hub caps on the wheels.
Old 09-27-2013, 10:56 PM   #10
65truckowner
Thanks for all the input guys.
