Old 09-27-2013, 12:24 PM   #1
Lou Boffa
Lou Boffa's Avatar
brake booster advice
Would you go 7" dual or 9" single booster on a drum/drum upgrade...or doesn't it make a difference in braking improvement?
Figure out what you want--then figure out what you are willing to give up to get it.
Lou Boffa is offline   Reply With Quote
Old 09-27-2013, 03:10 PM   #2
Lou Boffa
Lou Boffa's Avatar
Re: brake booster advice
Old 09-27-2013, 04:00 PM   #3
Longhorn 70
Longhorn 70's Avatar
I can't answer your question directly. I can only imagine that a 7" single stage should be enough for a single master.
I run a dual master with disc/drum and use a dual 9" booster. It almost feels too soft at times.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 09-27-2013, 04:21 PM   #4
68gmsee
Active Member
68gmsee's Avatar
The dual diaphragm is recommended for disc/disc because of the higher psi. If that's your future plan, I'd go with that.
Here's a quick explanation:
Dual Diaphragm Boosters
The website of MBM Brake Boosters states that disc brake systems require 1000 p.s.i. to be applied to the wheels. Dual diaphragm brake boosters are need for four wheel disc system because they can produce a higher level of brake assist even if their physical size is smaller. Dual diaphragm brake boosters tend to give extra braking even when the vacuum from the intake manifold is low.
Read more: http://www.ehow.com/about_6048376_si...#ixzz2g7XNBvfo
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 09-27-2013, 04:32 PM   #5
Lou Boffa
Lou Boffa's Avatar
I'm sticking with my drum/drum set up.
Thanks for the feedback. I had heard a dual booster on drum/drum can make the brakes feel too light. Dont mind some effort but not the "I'm going to die" sensation I occassionally have with my current unassisted dual MC set up.
Sounds like a 9" single will do the trick.
Old 09-27-2013, 04:56 PM   #6
quick60
quick60's Avatar
I have drum/drum and a dual master cylinder. I do not get very good brakes at all. Is that normal? Yes I know the im going to die sensation and dont like it at all.
I had a Nova that did not have power brakes and it had decent brakes. I was very surpised at my 67 3/4 tons lack of braking.
quick60 is offline   Reply With Quote
Old 09-27-2013, 05:01 PM   #7
Lou Boffa
Lou Boffa's Avatar
I think its pretty normal for unassisted truck brakes. My '54 1 ton was definitely like that. I can still lock the wheels on the '70 if I bear down hard enough. I dont mind the effort but I would like to avoid the occassional need to change my trou.
Old 09-27-2013, 05:02 PM   #8
tony58
7" is way too small for a heavy truck. OEM is 11" single. The 8" dual will give about the same assist as the 11" OEM single. 9" single will be a little less.
tony58 is offline   Reply With Quote
