09-28-2013, 09:15 AM | #1 |
trailer brakes and wiring
I just bought an old 22 foot camping trailer for hunting season and need to wire up a brake controller and convert from my 4 wire plug to 7 wire for the trailer.
What is a good brake controller for less than 100 bucks and how hard is the installation? Any easy tricks to wiring up the 7 wire connector? I plan to leave the 4 wire in place for my tow dolly. Thanks for any help.
1989 Silverado K2500ECLB- 307K miles with 90 K TBI 350-Not a show truck, a work tool that I can drive! 1998 Dakota EC 250K miles- I guess I'm just a truck guy now! |
09-28-2013, 09:21 AM | #2 |
Re: trailer brakes and wiring
I have the same issue. Subscribed.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
09-28-2013, 10:00 AM | #3 |
I think they have adapters from 4-7 pin's if not ya can wire your own adapter it's not hard but you'll only have trailer lights as that's how mine is
When in doubt, throttle it out! 1974 Chevrolet Custom K20 2005 Ford Ranger Edge 1985 Chevrolet Custom Deluxe C10 |
09-28-2013, 01:51 PM | #4 |
here ya go |
09-29-2013, 03:47 AM | #5 |
I used a cable from a RV repair place. It had 7 wires, color coded and all the right size wires for each application. I hooked up the front like the drawing and then hooked up to the 7 wire plug. I then soldiered my rear tail lights into the cable just in front of the rear bumper.
09-29-2013, 07:46 AM | #6 |
I just did this to my 87 v2500. I bought a 7 pin receptacle, Ckt breakers and a 2 wire 10 or 12 gauge cable from an RV shop but the parts can be found at some autoparts stores. I had additional wire and typical wire connectors on hand.
I ran the 2 wire down the passenger side frame inside some black wire plastic wire harness wrap with enough extra at each end reach the 7 pin receptacle location and the cab. Under hood I mounted 2 circuit breakers on the fire wall. Each breaker got power from the battery. One breaker output went down the 2 wire to the 7 pin connector and the other went inside the cab to the brake controller. There were 4 connections in the cab. The brake control was grounded and tied into the brake pedal wire. The power came from one of the ckt breakers from the fire wall and the controller output routed down the other wire to the 7 pin connector. At the connector I used the wires from the existing 4 pin, brake lights and a chassis ground. I mounted the 7 pin to the bumper to the drivers side of the hitch. To retain the 4 pin option I bought a plug that can be plugged into the new 7 pin that converts it back to a 4 pin and stored it in the glove box I wrote this from memory but I think I got it right. I also referenced the following websites. http://www.allpar.com/fix/electrical...er-wiring.html http://www.procarcare.com/icarumba/r...ia_towing1.asp http://www.sherline.com/lmbook.htm#refrn3 I also plumbed in a trans cooler, and trans gauge. Posted via Mobile Device Posted via Mobile Device Last edited by Pano; 09-29-2013 at 07:48 AM. Reason: Added info |
09-29-2013, 07:58 AM | #7 |
Also...I am using a prodigy 3 Brake controller that was given to me. I am told that most new tow vehicles come with brake controllers built in so guys that have towed for a while that have new trucks don't use them anymore. Thats why mine was given to me.
http://www.tekonsha.com/content/prod...ID=1435&part=0 http://www.pirate4x4.com/tech/billav...ng-generic.pdf Posted via Mobile Device Posted via Mobile Device |
09-29-2013, 08:02 AM | #8 |
Rottenwood Garage Member
I buy all my brake controllers off of craigs list. I just got a brand new in box CURT for $17. Works great. Its about the 4th one I have picked up with no issues. the wiring can be overwhelming but with the correct diagrams and understanding of what you are doing it can be done.
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! |
09-30-2013, 12:01 PM | #9 |
[IMG][/IMG]
Standard 7 way trailer wiring diagram. The best thing to do is to get out a test light to insure that each connection is going to the proper wiring. I have seen plenty of trucks and trailers that people have wired up to different color wiring. If you want to keep the 4 way plug and add a 7 way, the easiest way to do so is to splice into the 4 way and add the wiring for the brakes. wiring for lights is: Brown-Tail/Turn Yellow-Left turn Green-Right turn White-Ground |
10-02-2013, 10:27 PM | #10 |
I've read that Prodigy and Prodigy II are fantastic brake controllers, very easy to set up. Don't know if they meet your $100 price. Have the Prodigy on our C30 used to tow a horse trailer.
Whatever you do, don't put in a larger fuse for the parking light circuit to drive your trailer. Ours burned up the wiring in the truck from a trailer short. Went to the junkyard to strip out wiring to replace ours and I saw a lot of trucks there with wiring showing heat damage and a larger than stock fuse installed in the fuse panel.
86' C30 Dually Crew Cab Ranch truck, carb'd 454, TH400, towing a slant load 4 horse trailer. |
10-02-2013, 10:47 PM | #11 | |
I see you are in snow country, so one other tip is to make sure the adapter is supported or well attached to something other than the wiring alone. Otherwise, snow and ice will accumulate around the plug and eventually pull it loose. Not much fun to re-attach in the dark laying in the slush.
1980 K10 Suburban Silverado, original 350 w/Qjet swapped to 406sb, TH350C swapped to TH400/205 |
10-02-2013, 11:11 PM | #12 |
Ditto what SilverMiner said above. Etrailer.com is a good place to look at parts BTW.
12-19-2013, 03:42 PM | #13 |
12-19-2013, 08:32 PM | #14 |
i use one of the reese ones from walmart it does job. 50 bucks i think.
12-20-2013, 01:43 PM | #15 | |
Moderator
It has always bugged the $&%^*$ otta me that there aren't really any pinout standards for trailer wiring plugs other than a loosey goosey "it should work". It seems the trailer and plug manufacturers make their own "Standards". Not good engineering practice but great for creating angry customers. I've bought nine trailers in the last 30 years with 7way "Pollack Bergman" ( 6 flat with round center Pin ) plugs. Some of them had to be re-worked to match the truck or car socket wiring. The vehicles were supposedly wired according to a "standard" color code and pinout. The "standard" socket pinout matched the other cars, trucks, and trailers in the herd and some trailers from the get go. So... The front and back of the 7 round pin diagrams don't even agree with themselves in this link (aux and backup locations differ). The 7way flat diagram doesn't agree with the diagrams posted earlier in this thread either.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
