Old 09-28-2013, 12:39 PM   #1
classic66
55-75 frame swap to a 66 c10 frame
does anyone know if i could use a 66 chevy c1o frame to put a 56 chevy cab on it
classic66 is offline   Reply With Quote
Old 09-28-2013, 12:54 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 55-75 frame swap to a 66 c10 frame
Its not easy but it can be done, I assume your going with 66 because you have one. If your set on a reframe then try mid 70's early 80's. Same basic frame as 66 but has the updated brakes, suspension and steel.
dwcsr is offline   Reply With Quote
Old 09-28-2013, 01:29 PM   #3
poncho_villa
poncho_villa's Avatar
My '58 is on a '64 frame. I did not do the swap. It was already done like that when I bought the truck. So, yes it can be done. Take lots of measurements of mounting points and wheel bases and be prepared to fabricate brackets.
58 Apache short fleetside ona 64 chassis:
poncho_villa is offline   Reply With Quote
