09-28-2013, 04:24 PM | #1 |
exhaust question....
I'm gonna be placing dual aluminum exhaust on my truck after the crate motor is running.
I wanted to find out if I could use a bassani x pipe off a previous exhaust setup I have laying around.obviously ill be ditching the cats, but could it be used on my c10 , cutting it up is totally fine. I just love the sound of the bassani x pipes Posted via Mobile Device |
09-28-2013, 07:52 PM | #2 |
I am a Referee of life.
Re: exhaust question....
What's the diameter?If it's the size of exhaust you want to run,you should be able to use it,but good luck getting an exhaust shop to use something they didn't sell(other than a muffler or cat).The only other problem I can think of is interference.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
09-28-2013, 10:04 PM | #3 |
True they may be lame about it , its same diamater (2.5") same as what exhaust ill be running.
Ill take the x pipe setup to my mechanics and see what kinda clearance I'm working with. If I cut the part below the brace that sits below the cats wouldn't that be ok and still be functional?? Posted via Mobile Device |
