Old 09-28-2013, 05:00 PM   #1
Andrewb83
Andrewb83's Avatar
Removing 4x4 rotors
Trying to remove the rotors off the truck. I got the hub and 2 first rings off but am now not sure how to proceed. The repair manual is brutal for any good description. So I'm asking you guys for help. Here's a pic
Andrewb83 is offline   Reply With Quote
Old 09-28-2013, 05:02 PM   #2
Andrewb83
Andrewb83's Avatar
Re: Removing 4x4 rotors
Old 09-29-2013, 01:00 AM   #3
andrewmp6
You might have better luck in the 4x4 part of the forum.
andrewmp6 is offline   Reply With Quote
Old 09-29-2013, 08:47 AM   #4
LONGHAIR
If you already have both of the snap-rings out, the rest of the locking hub just pulls straight out. It may be crusted in there by dried mud, grease, etc.
Stick a screwdriver under the little tabs and pry at it a bit. There is a spring under it, so once started it will come right out.
Past that comes the need for a "special tool". The spindle lock nuts require a 4-pronged socket. The first one holds a locking ring that gets trapped between it and the inner nut. It just lifts off after you remove the first nut. After that is the second nut, same socket. If the usual chain type auto parts stores don't have the socket, NAPA will.
The only other thing holding the hub/rotor in place is the brake caliper. Two bolts and it lifts off, then the rotor will pull right off.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 09-29-2013, 02:37 PM   #5
Andrewb83
Andrewb83's Avatar
Thanks longhair got the rental kit at ct worked like a charm
