Rust in the gas vent lines.
If (as I expect) my fuel lines are rusty inside, do I need to worry about replacing the gas tank vent lines?
Re: Rust in the gas vent lines.
i doubt it
![]() Join Date: Dec 2010
When I got m truck, it had sat for quite a while. After the carburetor had to be cleaned TWO times, I pulled the tank, flushed it out many times and blue air thru all the gas lines. This was the only way it worked for me.
Active Member
![]() Join Date: Jul 2007
That's what ethanol does. If your vent line is rusted check the inside of the fuel tank. Seems like even the new ones will develop a film of rust fairly quick.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
68gmsee,
Way ahead of you man! The tank has been renewed.... Hmm.....that recondense line that goes up into the right rear cab pillar, I'll check with a q-tip but since that allows gasoline to recondense, I might better replace that. Oh geeze! I'm practically "restoring" my truck! ![]() |
