Old 09-29-2013, 06:34 AM   #1
scott-wisc
scott-wisc's Avatar
Flywheel Install
I took the flywheel off the old 250, and am about to bolt it to a brand new 350. Do I align the dowel holes up for proper orientation?
scott-wisc is offline   Reply With Quote
Old 09-29-2013, 09:54 AM   #2
hugger6933
Re: Flywheel Install
This won't help you any but since you have had several people look and nobody answer, are you sure that the 250 flywheel is the same as the one for a 350? I personally have never tried to change one so I would not know about the change over.
hugger6933 is offline   Reply With Quote
Old 09-29-2013, 10:14 AM   #3
68gmsee
Active Member
68gmsee's Avatar
I know it will fit on the older 350's -I put my old 250 flywheel on my 75 350. I'm not familiar with the newer engines so do don't know.
Anyway, yes, you just align the dowel hole on crank with the flywheel hole.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 09-29-2013, 10:22 AM   #4
68gmsee
Active Member
68gmsee's Avatar
Forgot to mention... some flywheels were drilled for the heavy duty cluch/pressure plate (like mine) and some were drilled for both.
06 Trailblazer
Old 09-29-2013, 04:33 PM   #5
scott-wisc
scott-wisc's Avatar
I lined up the extra hole, seemed like a no brainer.
Old 09-29-2013, 06:14 PM   #6
airdale94
airdale94's Avatar
They interchange as long as it's not the one piece rear main 5.7l.
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member).
airdale94 is offline   Reply With Quote
