![]() Join Date: Jul 2013
door panel and arm rest removal.
I nerd to pull the driver side armrest and door panel off my truck. I can't see what's bonding the arm rest on . Flat head , Phillips, or bolt . Its on a 1972 GMC. Can anyone help me out ?.
Posted via Mobile Device |
![]() Join Date: Apr 2012
Re: door panel and arm rest removal.
Should be a large phillips.
I'll give it a try thanks
your gonna need a door window roller crank tool if you dont have one. It is kinda flat and has a u-shaped groove in the end to push the clip off the window roller. A tip the clip opening should line up with the end you put your hand on to roll the window.
You can also remove that clip with a 90 degree bent dental pick.
Look closely with a flashlight. You'll see the clip and how it fits. Do one side and keep the other door intact so you have a reference for putting it all back together. |
#6 | |
Ask me how I know! ![]()
Willie Swamp Angel Truckers '72 C10 Highlander ![]() People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. ![]() |
