Old 09-29-2013, 04:34 PM   #1
Mondo
Mondo's Avatar
Truck Upgrade
Well my old motor finally gave up the ghost and other projects took priority. So my truck sat for almost two years.
But now it's better than ever. I put a 5.3 drivetrain from a 2008 GMC 1500 with 40,000 miles in it (never mind the engine cover). Plus I had a rack & pinion from No Limit installed as well. It's as close to a new truck as I'll ever get. I'm very happy!
Mondo is offline   Reply With Quote
Old 09-29-2013, 04:38 PM   #2
Mondo
Mondo's Avatar
Truck Upgrade2
couple more pics,
there's not much out there for engine covers. While not a 6.2, I liked the cover.
Old 09-29-2013, 05:28 PM   #3
tommys72
tommys72's Avatar
Re: Truck Upgrade
Couple nice upgrades. .. nice truck
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline   Reply With Quote
Old 09-29-2013, 06:27 PM   #4
Andy4639
Old member
Andy4639's Avatar
Wink Re: Truck Upgrade
Nice swap man!
I have a 6.0 fixing to start on mine I hope in the next few weeks.
You can check the link in my sig to see what I have done so far.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 09-29-2013, 07:27 PM   #5
hugger6933
Re: Truck Upgrade
I wished I hadn't seen this thread, I have three trucks and about five of these motors laying around from 4.8's to 6.0's from trucks I've junked. Now the wheels are a churnin. Is the rack on this truck off of this body style truck as well that the kit uses?
hugger6933 is offline   Reply With Quote
Old 09-29-2013, 07:41 PM   #6
wesmigletz
wesmigletz's Avatar
Re: Truck Upgrade
I love the factory look to your engine compartment. I hope mine will look that clean when I finally get around to it.
What motor mounts and radiator did you use? What application are the radiator hoses from?
1970 2WD K5
1968 Camaro Conv
1967 Chevy SWB
1964 Malibu SS
1957 Corvette
Pics
www.picturetrail.com/wesmigletz
wesmigletz is offline   Reply With Quote
Old 09-29-2013, 07:41 PM   #7
hugger6933
Re: Truck Upgrade
Old 09-29-2013, 07:46 PM   #8
Mr Chevorlet
Rusty Nuts
Mr Chevorlet's Avatar
Re: Truck Upgrade
Nice truck, well done job
(Clever Missouri) Southwest
Larry
Mr Chevrolet
My Build, The Marathon Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=604414
Mr Chevorlet is offline   Reply With Quote
Old 09-29-2013, 10:34 PM   #9
Mondo
Mondo's Avatar
Re: Truck Upgrade
Hugger,
You can get the rack from Brothers or No Limit (same kit). Little over a grand when all said and done. Drives really nice.
Old 09-29-2013, 10:49 PM   #10
Andy4639
Old member
Andy4639's Avatar
Cool Re: Truck Upgrade
Originally Posted by Mondo View Post
Hugger,
What does the rack get u over a normal power steering setup if I may ask other than the cool factor!
I do like the fact of the cool part though for sure. Just wondering what the advantages were of it.
Old 09-29-2013, 11:31 PM   #11
Mondo
Mondo's Avatar
Re: Truck Upgrade
I went through several steering boxes; standard, quick ratio, variable... they all develop that old school slop; that 1/4in of nothing gradually grows to almost inch. You can tighten the box but if you do it too much it will lock up.
I found the "red top" brand, "variable ratio" to be the best box but I've always liked how rack and pinion feels. So when this came out I thought I'd give it a try.
Old 09-30-2013, 02:03 PM   #12
cwilkie
Chance
cwilkie's Avatar
Re: Truck Upgrade
According to the kit on BROTHERS a PS pump, brackets, and hoses are needed in addition to this setup. What did you use for these required parts? I have a 1972 style pump, brackets, and hoses on my 1968. Will my current parts work. My gear box always seems to leak and I have changed it twice but after a period of time it starts to leak again.
Detailed Description
Finally, a Rack & Pinion Power Steering System for your classic truck. BROTHERS 1967-72 Rack & Pinion Power Steering Conversion is awesome! Kit comes complete with: power rack & pinion unit, rack mounting kit, rack mounting hardware, billet rack clamp and hardware, steering support bearing and hardware, lower steering column shaft with u-joint (welded), as well as an outer tie rod kit. Note: drop spindles require 17" or larger wheels. Requires PS pump, brackets and hoses.
1968 Chevrolet Stepside
BB 396 w/TH400
1972 Chevrolet 3/4 Ton 4x4
BB 496 w/TH400
cwilkie is offline   Reply With Quote
Old 09-30-2013, 08:42 PM   #13
Mondo
Mondo's Avatar
Re: Truck Upgrade
I had the work done but I think the only issues to come up were changing fittings to hook up to the power steering pump and we needed another joint in the column. Remember, I put in a 2008 engine. It was above my skill level and I bet a lift would be worthwhile. I think there are instructions on the No Limit site.
Drove it to work today (70miles round trip) and it was great. With new shocks and springs, going around corners at average speeds without a sway bar is hardly noticeable... I said "average".
