Old 09-29-2013, 04:56 PM   #1
GoDaddyRacing
How low?
Wondering how low I can get the front end of my85 C10 using the stock front inner fenderwells before I run into tire clearance issues. Will be running a 20" front wheel and want to use a 245/45 20 front tire (28.6" tall)
Does anyone here have experience in really getting these trucks down and retaining the stock inner fenders?
Please advise....wanting to tuck the sidewalls of the front tires and still be able to 'drive' the truck
GoDaddyRacing is offline   Reply With Quote
Old 09-29-2013, 08:23 PM   #2
Pro Performance
Pro Performance's Avatar
Re: How low?
I would suggest going 4.5 on the front, which is a common drop and should get it close to tucking. You might be able to go another .5" lower, depending on offset of the wheel. I think anything lower and you will hit the fender wells under harsher bumps.
Travis
Pro Performance is offline   Reply With Quote
Old 09-29-2013, 08:24 PM   #3
eray92
eray92's Avatar
Re: How low?
im running a 255/45/20 which is 29" tall and my truck is lowered around 3-4"s with no problems.
eray92 is offline   Reply With Quote
Old 09-30-2013, 12:57 AM   #4
jbristo67
resident oilfield trash
jbristo67's Avatar
Re: How low?
I've dropped one 5-7 with your wheel and tire setup
1967 SWB C10 396/400 factory air
factory tach (sadly had to send to a new home)
1986 Honda 70 Fourtrax
1991 Chevrolet K5 blazer 2wd
1982 Mastercraft Pro Star 190 Stars and Stripes
2002 Chevrolet Tahoe
2011 Nissan Armada
jbristo67 is offline   Reply With Quote
Old 09-30-2013, 09:38 AM   #5
GoDaddyRacing
Re: How low?
Hey jbristo67, did you have any tire to fenderwell clearance issues?
BTW, the front wheels will be 8.5" wide w/5.25 back spacing. Truck will have CPP spindles which I'm told will pull the wheel inward another .25"...
Old 09-30-2013, 11:38 AM   #6
Blackpony
Blackpony's Avatar
Re: How low?
I am running djm drop arms with stock springs that have one coil cut out. Running 255/55-18 tires which are 29" tall and I rub when turning and I hit a bump. Going straight it's pretty good I think the bump stops hit before the tire rubs. I need to trim te bump stop though as I have abou 2.5-3" of travel before it hits.
Blackpony is offline   Reply With Quote
