Old 09-29-2013, 04:59 PM   #1
gmc396
Question on Guages
I recently bought a 1968 GMC Custom C2500 PU. It has a tach in the center of the large speedometer on the left and large gas gauge on the right. On the bottom is spaces for 2 smaller gauges on either side of the steering wheel. The small, lower gauge just to the right of the steering wheel is blank. Was a clock an option for that space?
Also, the truck has 396 V-8 badges on the lower front fenders. These were typically seen on Chevy vehicles. Are they stock, or were they added?
Thanks for your help. I'm new on the forum and enjoying all the information.
gmc396 is offline   Reply With Quote
Old 09-29-2013, 06:12 PM   #2
airdale94
airdale94's Avatar
Re: Question on Guages
I believe it's a vaccum gauge option.
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member).
airdale94 is offline   Reply With Quote
Old 09-29-2013, 06:22 PM   #3
Andy4639
Old member
Andy4639's Avatar
Talking Re: Question on Guages
No clock in these years from factory. The stock opening on the bigger trucks had a vacume gauge in that spot. U can make a newer clock work though if u want. Here is my setup with Tach,speed warning buzzer and clock in the dash.
Took the dash out and put all new Speed Hut gauges in it now. This one is on the shelf in the garage.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 09-30-2013, 10:59 AM   #4
gmc396
Thanks or the info. I had a '67 SS Chevy with a vacuum gauge (but no tach). Always considered it a bit useless; recall the owners manual linked it to fuel economy...
Old 09-30-2013, 11:59 AM   #5
Chulisohombre
Chulisohombre's Avatar
The vacuum guage helps when finding optimum mileage. 14psi I believe is the perfect optimum psi to be at. When adjusting timing it can help to see how close to that number it can get as well. It's old school tech but still helpful.
Chulisohombre is offline   Reply With Quote
