Old 09-29-2013, 07:26 PM   #1
bodydrop
65 c10 airbagged
I recently bought a 65 c10. I am goin to put porterbuilt suspention and goin to notch the rear end. But I would like to tow stuff with it. How do u setup the bags for smooth riding and towing?
bodydrop is offline   Reply With Quote
Old 09-30-2013, 09:42 PM   #2
cubber
Re: 65 c10 airbagged
Someone will chime in that probably knows more than me, but bags will support extra weight better than springs if they are sized right. There has been a lot of talk about notching a tow rig, though. They say that the weak spot where the frame has been cut could be dangerous. Depends on what you want to tow, I guess. I recommend the Porterbuilt notches, though, either way. That's what I have on my truck, and they are built a lot more substantially than some of the others.
=MATTHEW
69 Stepper...Stroked & Bagged GONE BUT NOT FORGOTTEN
2003 Chevrolet Z71 Ext. Cab
1995 Cavalier gas saver!
cubber is offline   Reply With Quote
Old 10-01-2013, 10:14 PM   #3
Pro Performance
Pro Performance's Avatar
^^^ very true. It does depend on how much you are looking to tow. The Porterbuilt notches are built stronger than any other ones out there in my opinion. Let us know a little more info on how you plan to use the truck.
If you are using the Porterbuilt suspension, it would be already designed to work altogether. What system are you looking to purchase from them? The Stage 2 kit, Extreme, etc...???
- Travis
Pro Performance is offline   Reply With Quote
Old 10-02-2013, 01:26 AM   #4
andrewmp6
Most companies will say not to tow with their notches just for the legal reasons,But i fully trust Porterbuilt's notches they are over built vs the frame it replaces.As long as you don't haul over what the bags can handle and truck can handle it should be fine to haul or tow with to me.
andrewmp6 is offline   Reply With Quote
Old 10-02-2013, 01:43 PM   #5
68 Longbed Dan
There is a company that will make mandrel bent 2x4 rails. You could always go that route, and have them bend you a custom set of rails. Something like this:
Dan
1968 Longbed Stepside C10
68 Longbed Dan is offline   Reply With Quote
Old 10-03-2013, 08:17 PM   #6
bodydrop
Just like tow a car or a light truck. But Im goin to purchase an extreme dropmember
Old 10-04-2013, 11:09 AM   #7
jimmydean
jimmydean's Avatar
I would call Nate or Dave and talk to Porterbuilt directly. I know a few rigs on here that use his stuff and tow, but he would have all your answers.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
