Steering component issue, HELP
Im finally converting my 65 C10 to front disc. I'm using donor 83 c10 spindles.
My problem, The outer tie rod ends.. On my 65 the tie rod end threads are 5/8. On the 83 they are 11/16 thread. The 65 tie rod end adjusting sleeve wont expand enough for the 83 TR end to screw in... I can't find any parts sites that give these measurements. Are 5/8 thread TR ends available for 83 spindles? I'm ready to make my own, but thought I'd ask first.... Thanks
"Sucks to be you" Suxtobu65
#2 | |
Re: Steering component issue, HELP
try this it may be what you need
this should help http://67-72chevytrucks.com/vboard/s...d.php?t=332740 the one above did not work for me
60-66 Nut
![]() ![]() Join Date: Mar 2007
I've always just changed the entire steering linkage to the later model assembly. You will have to drill 2 holes to mount the later model idler arm though. Then there's no confusion later on when you need replacement parts.
| Bookmarks |
