CPP Trailing arm crossmembers with exhaust cutouts?
I can't seem to find what I'm looking for. Are there any discussion threads on here with comments about running one of these? Sure seems like it would be nice to be able to run my exhaust thru there.
Are they worth the money? |
Re: CPP Trailing arm crossmembers with exhaust cutouts?
I have the ece cross member and like it. You can always take a hole saw to yours and sleeve it to save money
Scott 67 c10 sold 89 c1500 90 k2500 91 s10 #chevyonly ![]() |
Moderator
![]() Join Date: May 2007
The nice thing about them is they also have the trailing arm mounts flipped for improved pinion angle on a lowered truck. I plan to install one when I swap out rear ends.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
I'm running the CCP cross member with the exhaust running through them. Works great, my exhaust does not drop below the frame anywhere except way out back where it exits.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
Anyone have pics of their crossmembers cut out, or aftermarket? I've been toying with the cutting method, found a couple tubular, and other aftermarket crossmembers, but wasn't sure exactly which way I wanted to go.
I stopped adding up how much I spend on my builds, it only makes me doubt my sanity knowing I've spent more than 9 times it's original value new.
![]() Join Date: Sep 2012
I just cut 4 inch holes through mine with a torch. I admit it is only temporary untill I get the tubular one, It does the job but not near as clean as plasma or hole saw. If you want to save money cutting in the original is ok, if you want to go nice and clean then get the tubular. I myself was worried about cutting in the original and still having crossmember integrity but seems to be doing just fine.
@jmorri34, that was my thought too. I have my ls1, but can't seem to bring myself to buy the transmission. I know when I get the trans, I'll need a new crossmember, driveshaft, torque converter, etc... I would like to get my exhaust done now. I'll get all the other crap next feb when the next build phase kicks in.
![]() Join Date: Jul 2010
I welded a 4" ring to accommodate the 3" pipe. This helped strengthen the crossmember.
Posted via Mobile Device Posted via Mobile Device
Mark 1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20" My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609. My first start up http://youtu.be/R899YQ1OcjU |
#9 | |
I agree completely here, if you can weld in a ring it is much better!!!
Looks good trkfrk!
Yeah I have no plans on drag racing this thing, just don't like that ugly exhaust hanging down.
Looks good trkfrk! Thank you for the pic, I have an idea now. All i've seen so far was some torch pops.
![]() Yeah I have no plans on drag racing this thing, just don't like that ugly exhaust hanging down.
#13 |
![]() Join Date: Jun 2012
kind of a crappy pic, but you get the idea. I got carried away with 4" schedule 40 pipe and some gussets..
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker ![]() |
#14 |
Ece for comparison Posted via Mobile Device
#15 |
67-72 parts collector,…
![]() Join Date: Nov 2002
And there is always Porterbuilt,...
http://www.porterbuiltfabrication.com/?p=298
#16 |
Moderator
For $50 more I think I would go with the Porterbuilt cross member...way more options for dialing in your rear end. Does anyone know if there is a lead time on these?
#17 |
I'm sure there is.
But I hear their new water jet and press brake are speeding up production times.
#18 |
Wow. Thanks everyone! I like the options on the porterbuilt crossmember. Is there as much driveshaft clearance?
Am I the only one who has a hard time with the search feature on here? This can't be the first thread one these. |
#19 |
I really like the porterbuilt as well, if I go that route I am definately goin with them. As far as search goes, Make sure the bullet is on the 67-72 chevytrucks spot and you will get all the posts easier, beyond that if you are Im not sure
#20 | |
Lots of room for cycling the suspension. They also make a trailing arm crossmember for extreme dropped trucks with a 2-piece driveshaft that has a carrier bearing mount. And even a 4-link or leaf spring crossmember that allows room for the exhaust to pass thru with no trailing arm mounts.
#21 |
Thanks! The porterbuilt crossmember just looks awesome. Kind of a shame to run something that niceand not be able to see if.
Posted via Mobile Device |
#22 |
how did you get the member in with out cutting all 5 rivets out of the both ? did you spread the frame
69 step side http://67-72chevytrucks.com/vboard/s...d.php?t=613407 Last edited by keh27; 02-10-2014 at 06:29 PM. |
#23 |
You've gotta remove the rivets in order to change out cross member. It went in easily and didn't have to spread the frame
#24 |
got it done, thanks man
69 step side http://67-72chevytrucks.com/vboard/s...d.php?t=613407 |
