09-30-2013, 12:31 AM | #1 |
Lost placement on gearbox.
So the gearbox on my 71 was leaking power steering fluid so I removed it and replaced the seals where the steering shaft connects. When I did this, I marked the relation to the pitman arm buuut... my marking was not made good enough and rubbed off when I was replacing the seals.
I know I didn't move the gears too much as I did not dismantle much of the gearbox but I've also never messed with one of these and am unsure what I should do. Is it typical that being off by a small amount can be adjusted during an alignment or do I need to do something more here? |
09-30-2013, 02:31 PM | #2 |
Re: Lost placement on gearbox.
Bump.
09-30-2013, 04:03 PM | #3 |
The pitman arm will only go on one way in relation to your truck. Actually it goes on in 4 positions but none of the others are anywhere close.
09-30-2013, 04:07 PM | #4 |
Spin the steering wheel to the center between locks. Spin to one lock slowly then to the other counting the turns. Divide by 2 and spin back. Put the front wheels straight ahead. This will give a rough center to the gear box. Next, put the pitman up and see what goes.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
09-30-2013, 05:14 PM | #5 |
Sounds easy enough. I'm glad I didn't screw it up too much. Thanks for the advice guys!
