Old 09-30-2013, 08:31 AM   #1
bigmac73
bigmac73's Avatar
Ring Gear change
How much of a difference would i see if i went with a 3:42 ring and pinion. I currently have the factory 3:73 rear end.
I want to keep my low end power but have a little better MPG and lower engine RPMS at highway speeds
i do have a 2000RPM stall converter
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 09-30-2013, 08:39 AM   #2
Bigdav160
Bigdav160's Avatar
Re: Ring Gear change
A 3:42 adds one tooth to the pinion. So roughly a 10% change.
If you're turning 3000rpm on the freeway, after the change 2700 rpm.
If you were getting 10 mpg, expect 11
An overdrive transmission is about a 25% change.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 10-01-2013, 11:44 PM   #3
bigsnookmaster
bigsnookmaster's Avatar
I would go with the overdrive.More expensive, but pays bigger dividends in the long run!
bigsnookmaster is offline   Reply With Quote
Old 10-02-2013, 02:42 AM   #4
WIDESIDE72
WIDESIDE72's Avatar
not worth the troubel/ expense to swap from 3.73 to 3.42,IMO. Same could be accomplished with taller tires.
WIDESIDE72 is offline   Reply With Quote
