09-30-2013, 02:41 PM | #1 |
Help me find 73-87/91 engine mount stands
I'm looking for the bracket that attaches to the crossmember and frame rail. Motor mount attaches to the bracket I'm in need of...
I've searched and searched so far I found one online vendor that sells the LH side only. I greatly appreciate any help. If you have a link or have a set of these brackets/stands or whatever they're called, text me a price or post up here although I'm not in here all that often. Thank you!! -Joe 6517758 seven six one Posted via Mobile Device
1986 IROC-Z lS1/T56 Moser 9" 78mm Turbo 1968 C10 step side, 5.3 Maggnacharger TVS1900 6L80E 2009 CCSB 5.3/6L80 4x4 http://members.cardomain.com/gflo383 |
09-30-2013, 02:48 PM | #2 |
Re: Help me find 73-87/91 engine mount stands
Are you looking for #1 + #2 or #4 on this page of the LMC bible?
http://www.lmctruck.com/icatalog/cc/full.aspx?Page=53 Those are available from LMC, and likely your local auto parts store. |
09-30-2013, 02:56 PM | #3 |
None of the above. The larger metal brackets that come w/ the swap mount kit in the link:
http://www.earlyclassic.com/catalog....ry=New%20Items Posted via Mobile Device
09-30-2013, 02:57 PM | #4 |
I don't want their swap kit, just the frame mounts/brackets.. Does that make sense?
09-30-2013, 03:06 PM | #5 |
If what you are after is the large flat-ish things that the motor mounts(lmc #1 or #2) bolt to, try your local pull a part or salvage yard. Not sure what the proper name is either. At least around here, those things are often still on the picked over remains when they are sent to the crusher.
09-30-2013, 03:06 PM | #6 |
I'm not sure I've ever seen those outside of swap kits and rusty 4x4 frames in the grave yard. Have you tried the junkyard route?
09-30-2013, 03:09 PM | #7 |
Tried all the local junk yards, nothing. Might have to just buy the whole kit!
09-30-2013, 03:26 PM | #8 |
I have heard those referred to as pedestals. The bracket that sits roughly at a 45 degree angle, from top of frame edge down to crossmember that the motor mount itself bolts to.
There are dozens of them at the wrecking yard I work at on occasion. (The occasional Saturday or weekend.) #1 in GMs picture? 2WD, I assume... Looks like they call it an Engine Mount Bracket...
Devin 1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt 1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050 1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350 My Introduction with my '83s History New Daily, the '96 Last edited by 83GMCK2500; 09-30-2013 at 03:38 PM. |
09-30-2013, 11:25 PM | #9 |
Suburban Hick
I know for a fact I have 2 sets of the 2wd ones and I believe one set of the 4wd ones and soon to have a second set. Pm me if you're interested.
Mathew 1947 Chevy 3600 1951 GMC 100 1969 Chevy C-10 396/500hp TH400 lowered 4" 1968 Imapla Custom 396/325hp TH400 "Grandmas Car" 1976 Crew Cab 4x4 diesel http://67-72chevytrucks.com/vboard/s...d.php?t=488505 1978 Chevy K-10 454 1983 S10 4x4 "Bumblb" (Grandpa's truck) 1993 Chevy S10 V8 conversion 1990 Ford Probe Gt 1992 Dodge W-150 "Old Man's Truck" 1992 Pontiac Grand Prix SE 1992 Mercury Grand Marquis-Mercruiser 2000 Ford F150 (Currently my mother drives this) 1946 Farmall H with Stan Hoist loader 1965 John Deere 110 1961 Wheel Horse " Rat Tractor" |
