09-30-2013, 03:23 PM | #1 |
Cab Corners or rockers first
A friend offered to help me start repairing the rust on my truck.
My rockers are in really bad shape, but I also need to replace at least one of my cab corners. Since I will be doing this piece by piece (Meaning just on the weekends as we have time and with my learning curve) is it better to replace the cab corners first or the rockers? Or does it really matter as long as I do one at a time?
71 swb 350/4sp manual 5/7 static drop |
09-30-2013, 03:32 PM | #2 |
Re: Cab Corners or rockers first
My understanding is that the corners are a bigger deal. You have to freaking remove the bed to do them. I'd do the rockers first, and then do the corners if you don't want to be down long.
Posted via Mobile Device |
09-30-2013, 04:35 PM | #3 |
Oh shoot... didnt even think of that...lol Good point
09-30-2013, 08:34 PM | #4 |
Junior Member
We found it to work best by doing the cab corners first and then the rockers. The doors should be on also so the cab corners and rockers can be properly aligned.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
09-30-2013, 08:39 PM | #5 |
You don't need to replace the entire cab corner, but only what you need. This leaves more room to go back another time if needed.
09-30-2013, 09:11 PM | #6 |
some times you can just make a small patch and weld it back in without using the aftermarket panel (and removing the bed)
it just depends how bad your cab corner is rusted good luck
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
09-30-2013, 09:21 PM | #7 |
Whatever you do first, don't weld anything solid, untill the other has been fitted. That way you can make adjustments if need be.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
10-01-2013, 06:58 PM | #8 |
dont forget to buy a set of rear pillars? Start on the rockers but the factory spot welds on underneath that connect it to the floor pan can be a pain to get all spot welds out hope that helps out
10-01-2013, 07:57 PM | #9 |
Cluster King
Leave as much of the original sheet metal as possible and always do the hardest part of the job first.
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com I am also a dealer for Counterpart for gauge cluster parts only. Also see my facebook page, CG&C |
10-01-2013, 11:22 PM | #10 |
I will second that!
