09-30-2013, 03:50 PM | #1 |
265 manifold/steering box
putting a 283 in a 53 1/2 ton pick up have a left side 265 manifold do i still have to move steering box
09-30-2013, 04:44 PM | #2 |
Re: 265 manifold/steering box
I had to move mine about 3/4" using spacers and longer bolts. The slight change did not adversely affect the drag link or steering.
09-30-2013, 04:57 PM | #3 |
thanks x, 6 cyl still in truck heard where some guys milled manifold a bit, can you still get to plugs i am just getting parts together what rear did you use any tips will be appreciated THANKS GENE
09-30-2013, 10:20 PM | #4 |
The two center plugs on the drivers side are a bear. I come up from the bottom with a box wrench. I used an 8.5" 10 bolt rear from a '76 Camaro and put it in with a CPP axle relocation kit using the original springs. I had to grind off the corner of the steering box to clear the exhaust manifold. Good luck. Best advice I have is focus on one thing at a time and complete it right before moving on. Make it steer, stop and go in that order.
