Old 09-30-2013, 11:00 PM   #1
Campbel45
Crossover vs. crossover high steer?
Well I was about to buy a new p/s gear but thought I might as well do this crossover deal while I'm at it and not need to worry about what direction I might be going in after I hit a bump
My 71' k10 has a 4" lift on 33s and I'm looking at offroad designs crossover kit. Excuse my ignorance but would I need the plain crossover or the crossover high steer? To my knowledge the high steer is to move the driver tie rod above the leaf to get it out of the way of potential spring flex. If I dont plan on ever wheeling would I need the high steer or is there something I'm not seeing?
And also is it a pain to drill and tap the passenger side knuckle?
Campbel45 is offline   Reply With Quote
Old 10-01-2013, 07:30 AM   #2
OLDCHEV4X4
OLDCHEV4X4's Avatar
Re: Crossover vs. crossover high steer?
If your never gonna wheel it then the high steer isn't necessary.
In order to mill, drill and tap the knuckle it needs to be accurately machined. This is the steering we are talking about here, you don't want that to fail and get someone hurt. Take it to a machine shop with the print off the easternet and let them do it right.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 10-01-2013, 12:15 PM   #3
Campbel45
Gotchya thanks for the info
Old 10-01-2013, 03:10 PM   #4
Dale99
If you never plan to wheel, just get the drop steering arm. Best 100bux I have spent.
I'm on 4" and 33 also.
2008 Sierra k3500 LMM
1994 s10 blazer 4x4
1991 Camaro Vert Rusted in Half RIP
1972 Jimmy 4x4 L05,4L60E,np205http://67-72chevytrucks.com/vboard/s...d.php?t=546364
1967 C10 L6/3tree(dads truck)
Dale99 is offline   Reply With Quote
Old 10-01-2013, 07:55 PM   #5
Campbel45
I thought I head crossover steering helps the steering offroading or not? Less darting around and more stability... am I incorrect? Would I even see any difference if I didnt wheel?
Old 10-01-2013, 08:16 PM   #6
Dale99
I know the drop arm I put on helped when hitting the bumps in the road and the steering wheel jerking left to right.
Old 10-02-2013, 12:36 AM   #7
argonaut
argonaut's Avatar
You only need crossover if you are planning to do major offroading that will cause you to cycle your suspension fully. With a stock setup if you have extreme droop on the driver front corner the drag link will be placed at am extreme angle, limiting steering. For most applications the stock steering system is adequate.
With a crossover system you will experience more bump steer coming from the passenger side. If setup with good geometry it won't be too noticeable.
High steer is all about getting the tie rod up above the springs and out of the way of rocks and debris, again most beneficial for offroad rigs.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 10-02-2013, 12:23 PM   #8
Campbel45
Oh okay gotchya. Well then I will go with just the 4x4 steering gear and call it a day.
Thanks for the pics argonaut your rig looks clean!
Old 11-22-2017, 07:46 AM   #9
Desy180
So much useful information. I am very glad that I joined you!
Desy180 is offline   Reply With Quote
Old 11-28-2017, 11:49 PM   #10
andyh1956
We got an 88 K5 4" + 33s. I was going crossover until I found out I would lose the sway bar. On my truck I wouldn't trade my sway bar for whatever benefits crossover offered. I used a drop pitman arm + a raised steering knuckle arm. Once the draglink got level bumpsteer was almost not noticeable anymore. Now I got a pair of flat top 44 knuckles & tie rod with no where to go!
andyh1956 is offline   Reply With Quote
Old 11-29-2017, 01:51 AM   #11
Sleeperc10
Check out Chassis Unlimited on google they are based in Livermore Ca. They make a kit for crossover or crossover high steer for a very reasonable price.
Sleeperc10 is offline   Reply With Quote
