10-01-2013, 08:54 AM | #1 |
1969 c-10 rear end question
I have a 1969 Chevy C-10 with a 12 bolt rear end with 3.73 gears in it. I am wanting to change the gearing to a 3.08 but I understand that I would need to change the carrier to make the 3.08 gears work. Can anybody tell me what vehicles would have the correct carrier that would fit in my rear end to allow the 3.08 gears to work. Would a mid 70 truck have the correct carrier in the rear end? Does anybody have a carrier they would sell for my needs?
Any help would be appreciated.Thanks |
10-02-2013, 07:45 AM | #2 |
Re: 1969 c-10 rear end question
Does anybody have any ideas on which year truck would have the correct carrier I need?
10-02-2013, 08:10 AM | #3 |
Ive been doing a little research and I dont see anywhere that says you cant install 3.08 gears.
Im a little curious as to why you would want to get rid of the 3.73 gears. They seem like the magic number for most builds.
71 swb 350/4sp manual 5/7 static drop |
10-02-2013, 08:56 AM | #4 |
From what I have been told is that the carrier that's in the rear end now are for 3.73 and up. If I want to go to a 3.08 gearing I need to change the carrier. I believe the carrier in it now is a series 4 and I believe I need a series 3 for the 3.08 gears.
When driving on the interstate the motor is running tight at 65 mph. Like to have it run less RPM at 65 mph and hopefully get better fuel mileage. Last edited by HowellKTM95; 10-02-2013 at 09:11 AM. |
10-02-2013, 08:57 AM | #5 |
It has a sb350 in the truck and a automatic 3 speed.
10-02-2013, 09:09 AM | #6 |
Would it be better to change the rim size instead?
10-02-2013, 09:20 AM | #7 |
The Older Generation
Depending on what brand of rear end you have It might be easier and cheaper to just change the whole rear end. I just did it on my '69 Suburban. Someone will correct me if I'm wrong but if you have the HO52 you can change the carrier as a unit. If you have a Dana you have to replace the ring and pinion gears. New gears are around 200 bucks and another $100 to install them and set them up. Unless you have experience in gear setup it may not be something you can do yourself.... LockDoc
10-02-2013, 09:28 AM | #8 |
Any suggestion on what year of truck rear end would fit underneath my with 3.08 gears. I currently have 6 bolt lugs. Would like to stay with a 6 bolt lugs so I don't have to change the rims and tires yet.
Thanks |
10-02-2013, 09:49 AM | #9 | ||
"I ain't nobody, dork."
There are a lot of 67-72 truck 12 bolts out there with 3 series carriers in them... There might even be 3.08 gears that are made to fit a 4 series carrier.
Need to do a little more research. What RPM's are you doing at 60? A stock SBC will handle 2,500 to 3,000 RPM's no problem. You're probably just used to modern engines with OD transmissions running at 1,600 to 1,800 RPM's on the highway. Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
10-02-2013, 09:59 AM | #10 |
I have searched online for a long time trying to find a used series 3 carrier for my rear end with no luck. Summit sells a carrier that will work, but a little high price for my blood at this time.
The RPM's are around 3000 at 60. |
10-02-2013, 10:44 AM | #11 | ||
3,000 at 60 is pretty normal for a SBC. They are made to handle it.
But I'm assuming that gas mileage is your main concern. 90% of the used carriers you're lookin' for are dang near 40 years old. A new one would be a good investment into the reliablitlity of your rig. Gary
10-02-2013, 10:50 AM | #12 |
My '69 and most came with 3.08 as standard equipment. So should be easy to locate a salvage. I'm now on 3.73 with a 29" rear tire and spin at 2800 down the freeway around 65mph.
10-02-2013, 10:54 AM | #13 | |
My (loose) understanding is that the series 3 carrier was sometimes used with 3:73's as well as the lower 3:08 ratio although I'm not sure how they defined the 3:73 gear set up to work with both carriers. If it has not been checked then I would start at that point rather than speculating. As well perhaps some of the other members who have done this particular change can point you in the right direction on the I.d. My two bits. Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
10-02-2013, 12:12 PM | #14 |
67-72 parts collector,…
Call these guys.
They can answer all your questions. No more guessing. http://www.ringpinion.com/Default.aspx
10-02-2013, 12:27 PM | #15 | |
2.73 and numerically lower (Series 2) 2.76 thru 3.42 ratios (Series 3) 3.73 & numerically higher (Series 4) Since ring gear inner dimension and bolt circle are different, the series 2, 3 & 4 gear sets are not interchangeable. Your carrier is a series 4. You will need a series 3 to fit a 3.08 gearset. |
10-02-2013, 05:28 PM | #16 |
Is your truck a coil spring truck or leaf? Changing the complete rear would most likely be the easiest and cheapest if you find a rear reasonably priced. They are not hard to find around here but maybe where you are they are. I generally scrap them, maybe I should rethink that.
10-02-2013, 05:38 PM | #17 | |
1969 Chevy C10 2wd stepside longbox |
10-03-2013, 01:32 PM | #18 |
My truck has coil springs on it. What year truck would have a 3.08 gears and 6 lug that would fit?
10-03-2013, 01:33 PM | #19 |
I have been watching E-Bay for awhile now with no luck. Will continue to watch though.
10-03-2013, 01:38 PM | #20 |
If anybody has a series three carrier for a chevy 12 bolt they want to sell please contact me. Thanks
10-03-2013, 02:27 PM | #21 |
Coil springs would be pre 72. Six lug would be 70 and earlier exceopt 4x4 but thats leaf springs anyway. I may accidently have a 3:07 carrier, i'll do some checking. I assume you want a ring and pinion too.
10-03-2013, 07:29 PM | #22 |
It looks like I have one with 3:07 gears. I'll need to pull it and see what kind of shape its really in.
10-03-2013, 07:45 PM | #23 | |
Codes stamped on the axle tube for 3.07 are: 3.07=HB, LL, RA, TR, TT (series 3) 3.73=HA, HJ, HQ, MF, TQ (series 4) |
10-03-2013, 07:50 PM | #24 |
My 70 K-10 had a 3:07 posi. Its on the SPID and my folks bought the truck new so I can verify. 4 low brake stands without the hubs locked broke it in half. So much for youth. lol.
10-03-2013, 10:05 PM | #25 |
I swapped the 3.73 open that was originally in my 71 GMC 6 cyl 3 ott for a 3.07 posi. A lot of the big block trucks had 3.07 posi rears.
