Old 10-01-2013, 12:16 PM   #1
etrone76
My 47/51/53 build
This is my first big project so Im learning as I go....building a mixture of 47-53 Chevy 3100 as a gift to my mom. Updated front suspension with a Mustang II set up, rear 4-link with coil overs, moved fuel tank to under bed, repaired/replaced rust, vintage air, LS 5.3 and 4L60 trans.....I have been working on during the weekends for about 3 months.
etrone76 is offline   Reply With Quote
Old 10-01-2013, 12:20 PM   #2
etrone76
Re: My 47/51/53 build
more pics....
Old 10-01-2013, 12:24 PM   #3
etrone76
pics of cab work.....
Old 10-01-2013, 12:27 PM   #4
etrone76
more cab pics...
Old 10-01-2013, 12:28 PM   #5
dmack91
dmack91's Avatar
Nice start. That is a lot of progress for a couple of months. Keep it up.
68 Chev C20- son has it now
83 K20 - bought from son
70 C20 - in progress
dmack91 is offline   Reply With Quote
Old 10-01-2013, 12:29 PM   #6
etrone76
steering column and pedal fabrication....
Old 10-01-2013, 12:35 PM   #7
etrone76
rear suspension work...
Old 10-01-2013, 12:38 PM   #8
etrone76
more rear suspension pics....
Old 10-01-2013, 12:44 PM   #9
etrone76
engine mounts....
Old 10-01-2013, 12:47 PM   #10
etrone76
Thanks, its kind of addictive....start working and before I know it I have been in the garage for 8-10hrs.
Old 10-01-2013, 01:30 PM   #11
Midgets50
Midgets50's Avatar
good progress so far looking good. yes these projects are addicting. over the summer i would lose track of time and spend over 12 hours working on it
Midgets50 is offline   Reply With Quote
Old 10-01-2013, 01:52 PM   #12
48 GMC BURB
48 GMC BURB's Avatar
Nice work
What type of tank & fule pump are you useing ?
48 GMC Burb
51 Chevy AD 3100/C 4 byShannon
74 Chevy P 10
48 Double Duty
04 SS Burb
01 Springer HD
48 GMC BURB is offline   Reply With Quote
Old 10-01-2013, 01:53 PM   #13
etrone76
Lol, I know what you mean....just one more thing....ok, one more. I work until Im so worn out I'm either tripping over stuff or dropping everything. Progress provides more motivation to keep going.
Old 10-01-2013, 02:01 PM   #14
etrone76
Originally Posted by 48 GMC BURB View Post
Nice work
Im using a 67 Camaro tank and either a "Tanks Inc" insert with 255 Walbro pump or the LS1 inline pump kit from Speedway Motors (p/n 91012805). I have both, whichever one I dont use on the truck will be used on my 67 Camaro LS3 swap I'm working on too.
Old 10-01-2013, 04:06 PM   #15
ricott
Great start to your project. Engine looks like it came out of a Trailblazer (front sump in the pan). What pan did you wind up using to get the engine in the truck?
ricott is offline   Reply With Quote
Old 10-01-2013, 04:14 PM   #16
etrone76
Thanks. The engine is an all aluminum 5.3 that came from a 2008 GMC Envoy Denali. When I got the eingine home I discovered that the short block was replaced with one that had a Mfg date of Jan 2012. I also have a an L92 6.2 LS from a 2010 Escalade that Im putting in a 67 Camaro and I used the pan from it. I think they are the same as the truck pans but I'm not 100% sure. The sump on stock pan from the Envoy went too far forward so the engine was really close to the firewall in the back and the front edge of the sump was almost touching the crossmember.
Old 10-02-2013, 08:15 AM   #17
Katrina/10
Katrina/10's Avatar
Nice work, why did you have to slice the crossmember?
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 10-02-2013, 08:30 AM   #18
L_Brown
L_Brown's Avatar
I am digging that rear suspension. Who makes it, would it work on a 56.
Larry Brown
North Texas
My 1956 Build - Huff Truck
http://67-72chevytrucks.com/vboard/s...48#post6308448
L_Brown is offline   Reply With Quote
Old 10-02-2013, 09:19 AM   #19
etrone76
I ordered the kit from Paul Hortons Welders Series, its a standard Triangulated 4-link kit so I'm sure you can make it work in your application. It was actually fairly simple to install, just alot of planning and measuring.
Old 10-02-2013, 09:21 AM   #20
etrone76
Thanks, when I was installing the Mustang II crossmember there was a small gap between it and the inside of the frame rails so I decided to cut about a 1/4 out of the center of the crossmember to pull the frame rails in tight to the crossmember. Luckily all the front sheet metal and radiator support still fit good.
Old 10-03-2013, 02:57 PM   #21
etrone76
Update: New complete bed from MAR-k is here, Gauges and rear QA1 coilovers from Summit and bench top bead roller from Eastwood. Hopefully I can get the coilovers and fuel tank mounted this weekend then test fit the bed............and tear it all back apart. Need to fab up a trans tunnel cover since I had to cut some out to get the 4L60 to fit adn fill the battery box cover in the floor. Then I will be ready to pull the cab off and finish cleaning up the frame to get it ready for paint.
Old 10-05-2013, 12:57 PM   #22
Katrina/10
Katrina/10's Avatar
There seems to be a lot of variation in those old truck frames and the crossmember kits out there. Since the sheet metal all sits on the center, it shouldn't cause too much a problem. Might have to bend the bumper brackets in a little bit.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Old 10-07-2013, 11:03 AM   #23
etrone76
Made alittle more progress over the weekend. Got the coil overs installed and the gas tank mounted, also made the battery box cover (moving battery) and trans tunnel.
Old 10-07-2013, 11:07 AM   #24
etrone76
a few more pics....
Old 10-07-2013, 12:02 PM   #25
69CST-V
69CST-V's Avatar
Nice progress. Subscribed.
Bryce
'69 SWB Fleet Still Under Construction
Company Trucks
69CST-V is offline   Reply With Quote
