07-09-2003, 02:13 PM | #1 |
where to fill this tranny
I am getting ready to put some gear lube in this here tranny and transfer case but I'm not sure how much and where to fill it at.
I have an SM465 and a Rockwell 221 I believe. I am guessing that you fill it till it comes back out but I need to know where to fill it and if there are any tricks to it. Thanks guys.
Jeremy '71 C-10 '72 GMC K2500 '72 Nova (Dad's) '70 Chevelle SS '55 Sedan Delivery Attempting to build up this here 4x4...make her real tall and purty...well, maybe just tall |
07-09-2003, 02:55 PM | #2 | |
Bloo
theres a little bolt on the side, square head, fill it untill it runs out a little... dont ask me HOW to do it though, i havent found an easy way
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
07-09-2003, 03:01 PM | #3 |
How Do You Do That?
Is there a separate fill for the transfer case or should it just go right in? You wouldn't have an idea of how many bottles of this crap I should buy do ya? Thanks for the help.
07-09-2003, 06:01 PM | #4 |
do yourself a favor and a get a suction gun it is a cylinder with a slide on it (to create the suction) andit has a hose on the end its the only easy non totally messy way to fill a rear or a manual tranny
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
07-09-2003, 06:23 PM | #5 | |
Bloo
not sure on the t-case but now that you mention it i need to check mine... im pretty sure theres a seal in there so you have to fill it seperate
07-10-2003, 01:50 PM | #6 |
So, I know someone has done this once before.
What I need the most is to know whether or not I will need to fill the transfer case separate or not. Good idea on the suction deally, I will get one of those.
07-10-2003, 05:27 PM | #7 |
Fabricate till you "puke"
Blue 71 has you covered on the T case. there is a seal tween the trans & case.....they fill separately. Dont ask me on the lube tho! I am running 30 weight motor oil in the t case on my 78 K 20. it hasnt caused any problems, so I guess its ok. good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
07-10-2003, 05:40 PM | #8 |
Ya know what, I think that answered everything. I guess I was just hoping that someone could tell me exactly what I wanted to hear but if I'd learn to read the message I could probably figure it out myself.
Now, let's try not to get lube all over myself. Thanks guys!
07-10-2003, 05:51 PM | #9 |
Yea man, that lube stinks! Try washing that out of the hair....All temp Cheer! its kinda rough on the scalp tho Good luck, crazyL
07-10-2003, 09:26 PM | #10 |
on the square bolt there, take it out, if you can touch fuid with your pinky finger, you dont need any more my friend!! Thats just on the tranny though------ killerbee!!
07-11-2003, 02:09 PM | #11 |
well I just filled both of 'em up.
If I did this right, the tranny took a gallon of this crap and the transfer case took about half a gallon or less. I don't think I coulda screwed it up but on my Rockwell 221 there are two sqare headed bolts about and inch apart on top of each other. I am guessing the bottom one to be the drain plug and the top of the two to be the filler.
