Old 10-01-2013, 03:40 PM   #1
motivman50
Question 62 wiring problem
can anybody tell me what I should do about my wiring? It use to have a 235 6 cyl now it has a 350 do I need to change the wiring harness? I have a billet dash guages set up Im putting in. It has idoit lights in it now and for the alternator its a one wire can anybody help?
motivman50 is offline   Reply With Quote
Old 10-01-2013, 04:06 PM   #2
b.sharp
b.sharp's Avatar
Re: 62 wiring problem
you do not need to change your wiring harness. You will need to install the corect sending units in the 350 to send the correct signal to whichever gauges you plan on using. IE, whether it is a mechanical or electrical gauge setup. Wiring should remain the same. I hope this helps.
b.sharp is offline   Reply With Quote
