10-01-2013, 05:16 PM | #1 |
intermittent start problem
Have 69 c-10 with a 350/std trans.Have replaced the starter with an ac-delco rebuilt,ignition switch,checked all wiring and connections between ignition switch and starter. will go for long periods of time with no trouble.
thanks Jim Ellis |
10-01-2013, 08:37 PM | #2 |
The Older Generation
Re: intermittent start problem
Is there any certain time it seems to do it? Maybe after you drive it for a while, when it's hot, when it's cold, more info might help nail it down... LockDoc
10-02-2013, 12:09 PM | #3 |
Lock doc,my intermittent start problem does it hot or cold.For awhile could try to start acouple of times and then it would start,but now it is getting worse
Thanks for your help Jim Ellis |
10-02-2013, 12:28 PM | #4 |
Check the wire from the + side of the battery to the junction block on the inside of the fender. Take the wires off of the junction block and clean everything up there. LockDoc
