Old 07-09-2003, 03:07 PM   #1
Canadian694x4
Born To Lose Club
Canadian694x4's Avatar
Location: Calgary, Alberta/Oxenden, Ontario, Great White North
Truck Running Badly...?
Topic: Well I was driving the truck the other day and as I approach a hill I give it a little gas. Now I can only explain this like it felt like it had no "pick up" or I was running on 6 cyls or sumthin cause nothing changed. It only seemed to "sound" different as the exhaust was a dead giveaway to a local admirer of my truck that it wasn't running well. It idles normal but when you hit the gas it seems to get noise-er and seems to lack it's original power. My engine is a 283, with a 4 barrel carb. Anyone have any idea what could be wrong?
Brian
Discuss...
Brian Smith - "Born To Lose"
1969 Chevrolet K10 LWB Fleetside - Proud Owner For 20 Yrs - 1 of 208 Built & Sold In Canada!
- 283 V8/350TH/NP208, 2" All Spring Lift, 32" Good Year MT/R's.
1972 GMC K2500 Custom LWB Fleetside - Proud Owner For 2 Yrs - 1 of 571 Built & Sold In Canada! - 350 V8/SM465/NP205, 4” Rough Country Lift, 33” Interco TSL Thornbirds
2007.5 GMC Sierra SLE 2500HD 4x4 - Proud Owner For 15 Yrs
- 6.6L V8 Duramax Diesel/Allison 1000, 2" Lift, 33" Mickey Thompson MTZ's.
2008 Yamaha Raptor 700r - Proud Owner For 13 Yrs - ITP Mud Lites.
2015 John Deere 1025R - Proud Owner For 6 Yrs - 24HP Diesel/H120/54D/260B/SB1154.
Canadian694x4 is offline   Reply With Quote
Old 07-09-2003, 03:11 PM   #2
tom hand
CCRider
tom hand's Avatar
If you are running points check the dwell...if it has closed up the truck will run as you discribed
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 07-09-2003, 03:41 PM   #3
wnc mountain
More hobbies than money!
wnc mountain's Avatar
Check the advance also, cintrifical may be stuck, or a spring is stuck if you have points. check the distributor cap for a crack, take a look at your plugs see if any look discolored, that could be a big clue as to what is going on.
'70 cst10/swb 350, 3 on the tree, factory buckets.
'70 GMC lwb 350/350 ps,pb
'72 c-10 lwb 350/350 a/c, ps, pb
'72 Blazer project
wnc mountain is offline   Reply With Quote
Old 07-09-2003, 04:13 PM   #4
COBALT
COBALT's Avatar
That sounds like your timing is too far advanced. Check your timing again with the vacuum advance for the distributor plugged.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 07-09-2003, 06:32 PM   #5
cdowns
cdowns's Avatar
besides timing points plugs condensor distributor cap sparkplug wires all of which have to be changed on a regular basis (routine preventitive maintenance) you also could check the fuel filter at the carb and the fuel screen in the gas tank
Old 07-09-2003, 08:51 PM   #6
Canadian694x4
Born To Lose Club
tune in to part 2 in a few moments...
