![]() Join Date: Apr 2005
My electric fan setup has a high RPM fan and a low RPM fan.
Question #1: which fan is considered the primary fan as far as the computer is concerned? high or low RPM? Question#2: which fan should I connect the trinary switch to? High or low RPM? Thanks in advance! Posted via Mobile Device
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 10-02-2013 at 10:22 AM. |
Re: Electric fan question
Question 1 low
Question 2 high My first fan on temp is 200 low speed second fan comes on at 215 high speed. In reality when the fans come on they just run full speed. I don't have anything that pulse modulates. That trinary will turn on the fan when ever the compressor is activated. You want as much air moving across the condensor especially when stopped. Just the way I will be wiring mine when my a/c goes back in. Posted via Mobile Device |
That's the same way mine is setup. Driver side on mine is low, passenger side is high side. I did set mine up just like factory, with a relay controlling each fan and a controller relay also. I still need to set up my trinary switch, but I understand some precaution needs to be taken when hooking up to the high fan. If done incorrectly it will supposedly cause the ECM to throw a code of some sort. I'm still researching the correct way to make it work.
Shawn Posted via Mobile Device
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
#4 | ||
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
Here's what someone posted and the correct way to wire the trinary and I agree stay away from the relays that the comp uses. This should prevent setting any codes.
![]() Posted via Mobile Device |
![]() Posted via Mobile Device Posted via Mobile Device |
Sorry for double post maybe a moderator can fix this
Roger. That's the schematic I was going to use. So use the low RPM fan with the primary trigger (from the computer) and the high RPM fan with the secondary trigger (from the computer) AND the trinary switch?.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 10-02-2013 at 10:24 AM. |
Yes that relay on the left is the stand alone that you will wire in. The positive wire that feeds the fan from that relay will just tie into the same positive wire That is currently feeding your "high speed" fan other words splice them together. This will demand the fan to come on any time the compressor is on. If for some reason the engine needs more cooling the computer will activate the high speed fan anyways and override the trinary in between let's say the compressor cycling. These two circuits will work together. Hope that makes sense.
Ok guys. Let's discuss this for a minute. My understanding is that the trinary switch will only kick on the fans when the pressure gets above a certain level. So for instance if your driving down the freeway the fans won't run just because the AC is on. If that is so, is there a way to run the trinary switch to the ECM so that when the pressure hits it will tell the ECM to turn on the fans? Seems like the system is already built into the ECM, it just needs a signal from the trinary to turn on the fan when pressure gets too high. Am I missing something? Here is how I wired my fans, minus the power train relay.
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE Last edited by jorgensensc; 10-02-2013 at 12:28 PM. Reason: Added pic |
A day late and $1 short...
I agree with the idea that there should be a way to send an "A/C demand" signal as well as a signal from the trinary switch to the ECM and have it control the fans. Isn't this how the factory cars work? I had to add another relay and tap into my #2 fan's power wire to get it to work.
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
Well, here is one reason mine wont work... Could someone be so kine as to explain how/what a trinary is?? I am just using a 30 amp relay to hook mine up but it wont work and this is probably why. Also, I don't have A/C for now.
Thanks for any help. Ben |
#13 |
The trinary switch is a part of the A/C system that senses pressure/temp to operate the compressor and cooling fans
#14 |
So I shouldn't need that at the moment correct?
#15 |
You need a trinary switch so that when you turn the AC on AND HEAD PRESSURE REACHES A PREDETERMINED LEVEL, the fan will turn on. Trinary switches don't just turn on the fan when you turn the AC on, which is where much confusion lies.
#16 |
#17 |
Hey buck! I hope you don't think I was trying to call you out. That was not it at all. I just keep seeing elsewhere that people keep saying the trinary makes the fan come on when you turn the AC on. I also see where people wire the fan to come on with the AC, but when your on the freeway cruising you probably don't need the fan on and running it can possibly damage the fans. That's why it's important to run the fan of the AC head pressure.
#18 |
No worries I understood your point, I guess I figured I could just state it generally. Everything you are saying is spot on!
#19 |
Cool, thank guys! and yes, I forgot to mention I was not running A/C at the moment.
#20 |
Where would you wire a 2-wire temp switch off the radiator in at on this diagram?
http://67-72chevytrucks.com/vboard/s...d.php?t=494388 431 big block times, changed to a 6.0 ls with turbo 1.58- 60' 7.18- 1/8th mile@95.18 11.37- 1/4 @115.81 |
#21 | |
![]() Join Date: Jul 2009
If you're using a temp switch, then I assume you aren't using the PCM to control the fans? Do you have A/C? Do you have one fan, two, or a dual speed single fan? If you have 2 fans do you want to run 1 for low and both for high or run both fans at half speed for low and both at full speed for high? If you provide some information about what you're trying to do and what parts you have, I could point you toward a schematic to do what you need. |
