Old 10-01-2013, 11:16 PM   #1
1969stepside
1969stepside's Avatar
led tail lights
this might have been posted before but here is my question well two questions really first i am converting my 69's tail lights to led and i am using the 55-57 stainless steel step side tail lights what all will i have to do to make this conversion possible and will i need any extra parts or new flasher with a ground coming off it? i can post pics if needed of the lights. second i converted my gauges to the white faced ones that come form whitegauges.com and i am a little worried about the numbers not showing up what can i do there any info on either of these problem will be helpful
Greater love hath no man than to lay down his life for a friend.
Members i Have met
Earl Slick68
1969 Stepside Build thread
http://67-72chevytrucks.com/vboard/s...=1#post4253546
Chevy Trucks the longest lasting most dependable trucks on the road
1969stepside is offline   Reply With Quote
Old 10-02-2013, 01:08 AM   #2
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Re: led tail lights
I put LED's in the rear and have regular bulbs in the front. So far no issues, no flasher change required.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 10-02-2013, 11:03 AM   #3
1969stepside
Re: led tail lights
i was at a car show and a guy said that if i didnt change it a ground-able flasher and ran regular bulbs that it would destroy my wiring harness
Members i Have met
Earl Slick68
Old 10-02-2013, 04:07 PM   #4
jmorri34
jmorri34's Avatar
Re: led tail lights
Smitty
I agree, I did the back as well and left the fronts alone and all is well no flasher or anything!
1969 cst prostreet
http://67-72chevytrucks.com/vboard/s...d.php?t=568661
jmorri34 is offline   Reply With Quote
Old 10-02-2013, 11:37 PM   #5
timski69gmc
timski69gmc's Avatar
Re: led tail lights
I was wondering about that too. If I changed to front LEDs, and or rear bulbs. Changing to a low voltage flasher, would that still power the regular bulbs. So, it sounds like changing just the bulbs is okay?
timski69gmc is offline   Reply With Quote
Old 10-03-2013, 11:44 AM   #6
jmorri34
jmorri34's Avatar
Re: led tail lights
I dont know this for sure, but from my understanding its this: I think we both did the same thing and just put LEDs in the rear and bulbs everywhere else and all worked well with regular flasher. I think where it changes is if you start adding LEDs to all the other lights and you get the voltage drop from all the other ones is where you get the problem with a regular flasher. I know that with leds in the rear it should work well and I would imagine if you add them to the front it may be ok but if your side markers flash and such and you LED all of them is where you will start having trouble flasher wise, maybe others will add in.
1969 cst prostreet
Old 10-03-2013, 12:20 PM   #7
MSHax
MSHax's Avatar
Re: led tail lights
I didn't have any issues with my LEDs and turn signals, but like a lot of other people here, I still have the standard bulb fronts. I actually went with LED side markers also. I wired them in so that that when the blinkers are on, the side marker will alternate with the blinker (long bed, gotta make sure people can see I'm turning when they're on the side of me).
I like the clean look of the LED
I stopped adding up how much I spend on my builds, it only makes me doubt my sanity knowing I've spent more than 9 times it's original value new.
MSHax is offline   Reply With Quote
Old 10-03-2013, 01:13 PM   #8
1969stepside
Re: led tail lights
that guy just freaked me out
Members i Have met
Earl Slick68
Old 10-03-2013, 01:14 PM   #9
1969stepside
Re: led tail lights
maybe he wanted me to buy a 25.00 flasher
Members i Have met
Earl Slick68
Old 10-03-2013, 01:49 PM   #10
Sammy
Re: led tail lights
I used 67-72 style in my GMC Step side. With 62 LED's per side in the rear with standard bulbs in the parking lights, markers. They were really slow when flashing until I traded out the flasher with an LED type. So guess it depends on the demand of your LED's etc..If the Lights you are using contain a lot of LED's as did mine you will notice a huge difference in the flash cycle.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 10-03-2013, 01:58 PM   #11
MSHax
MSHax's Avatar
Re: led tail lights
It is needed if you replace front and rear because the amount of resistance will be much less than a standard incandescent bulb resulting in a super fast flashing, or no flash at all. But from experience of mine, and the others that replied, as long as either the front, or the rear is a standard bulb, the flash speed is still good.
Old 10-03-2013, 11:11 PM   #12
sstaten69
sstaten69's Avatar
Re: led tail lights
My son has led tail lights, fronts and has led bulbs on the side markers also. havent had any problems.. Works the same as before.
sstaten69 is offline   Reply With Quote
Old 10-04-2013, 12:14 AM   #13
timski69gmc
Re: led tail lights
So, I guess the plan would be to try the bulbs, if it needs the flasher. then change it out. Easy!
Old 10-04-2013, 09:46 AM   #14
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Re: led tail lights
[QUOTE= I actually went with LED side markers also.
What LED side maker bulbs are those? They are bright!
Tom Vogel is offline   Reply With Quote
Old 10-04-2013, 09:52 PM   #15
1969stepside
Re: led tail lights
i am just running led tails
Members i Have met
Earl Slick68
Old 10-27-2013, 04:09 PM   #16
greyno3
greyno3's Avatar
Re: led tail lights
Got mine from LMC. Front/Rear and side marker LED's. . Couldn't figure out why blinkers didn't work till I saw this post. I just orderd a LED flasher. Do you need one for the emergency lights also?
greyno3 is offline   Reply With Quote
Old 10-27-2013, 09:44 PM   #17
timski69gmc
Re: led tail lights
Those look great. Guess I should get mine ordered as well.
I was wondering about the emergency flasher as well. I would think it is needed too.
Old 10-28-2013, 12:49 AM   #18
70cst
70cst's Avatar
Re: led tail lights
Great thread ...
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 11-13-2013, 08:10 PM   #19
Mayo
Cool Truck
Mayo's Avatar
Re: led tail lights
Did you have to hard wire those LED sidemarkers or do they plug into the existing sockets?
1968 Chevrolet C20 Longhorn "Cool Truck"
1937 Chevrolet Pickup - Project
Looking for a patina'd 68 50th Anniversary longbed
Mayo is offline   Reply With Quote
Old 11-13-2013, 09:30 PM   #20
Andy4639
Old member
Andy4639's Avatar
Wink Re: led tail lights
I ran LED's in the rear for a few years before I did the sides and front. I just have put the flashers with grounds in the truck when I did all of the lights.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 01-12-2014, 08:33 PM   #21
1969stepside
Re: led tail lights
how did u ground the flasher andy?
Members i Have met
Earl Slick68
Old 01-13-2014, 09:56 AM   #22
Andy4639
Old member
Andy4639's Avatar
The flasher I used had the ground wire on it. I just grounded it to the closet bolt in the floor I could find.
Sorry for the late post didn't see it until now.
Old 01-24-2014, 07:10 PM   #23
1969stepside
Re: led tail lights
i just got a two prong electronic flasher with ground where should i buy led 194s
Members i Have met
Earl Slick68
Old 01-25-2014, 04:01 AM   #24
Andy4639
Old member
Andy4639's Avatar
You should be able to get them about any parts house.
http://www.oreillyauto.com/site/c/se...yword=194+bulb
Old 01-26-2014, 03:43 PM   #25
1969stepside
Re: led tail lights
ok what about super bright leds? where did you get yours? these are for my dash cluster
Members i Have met
Earl Slick68
