Old 10-02-2013, 12:15 AM   #1
rustytruck50
rustytruck50's Avatar
Question about my just purchased '68 C10
I have a cab sagging dilema. After lots of measuring, I found that the cab support on the drivers rear has dropped about an inch, leaving the cab really close to the box on that side. A previous attempt at cab corner replacement omitted the rear corner filler panels on both sides that close the cab from the road. Long story short, is there a good temporary fix, like shimming that corner, that would be ok until those fillers were put back? Any help would be greatly appreciated!
rustytruck50 is offline   Reply With Quote
Old 10-02-2013, 02:14 PM   #2
dfwright
dfwright's Avatar
Re: Question about my just purchased '68 C10
Not sure what you mean by "filler panels"? Perhaps a picture or two would help to see what the problem is.
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 10-02-2013, 11:34 PM   #3
rustytruck50
http://www.lmctruck.com/icatalog/cb/full.aspx?Page=25
Callout #5 is what I'm missing on both sides
Old 10-03-2013, 01:19 PM   #4
dfwright
dfwright's Avatar
This is the cab floor piece for the back corner. Are you missing rear cab support piece that goes under the floor at this point? That would be item 16 on the diagram. If the cab is sagging in the back, the cab mount bushings may be shot. As long as the cab support brace is OK, and the Cab mounting bracket on the chassis is OK, you should be able to replace the cab mount bushing without too much trouble. You can search on the forum for "replace cab mount bushing without removing cab"
Old 10-03-2013, 01:22 PM   #5
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
I'm betting it's the cab mount bushings too. They are going to be shot after 40 plus years.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 10-03-2013, 01:46 PM   #6
rustytruck50
I have the #16s....I appreciate the help!
Old 10-03-2013, 01:47 PM   #7
rustytruck50
Gary
They don't look bad, but that is a real good point....Thanks
Old 10-03-2013, 02:30 PM   #8
dfwright
dfwright's Avatar
If the cab support bushing is OK, then it's hard to imagine how the cab could sag an inch without major structural damage to the cab support bracing or the chassis. Maybe you could take picture under the drivers side mount and post it up?
If there's no structural damage, and the bushing is OK, you can shim up the bushing as needed on that side to level the cab out.
