Old 10-02-2013, 12:18 AM   #1
blue694x4
gas tank conversion
I'm building a 69 body on a 86 1 ton frame. I bought a suburban rear tank for it. Is there a crossmember I need? The tank fits between frame rails, but there's nothing above it for the straps to hold it tight against. Any input or pics would be apprciated.
blue694x4 is offline   Reply With Quote
Old 10-02-2013, 03:47 AM   #2
1leglance
Re: gas tank conversion
I bought an 87 Suburban as a donor vehicle for my diesel swap and when I pulled the tank I also pulled the crossmembers.
They went right in nicely and make the tank swap a breeze.
You might find it easiest to just go hit a junkyard for the factory crossmembers.
1leglance is offline   Reply With Quote
Old 10-02-2013, 11:51 AM   #3
OldCreek
OldCreek's Avatar
I bolted in some angle iron and mounted the tank straps to that...
Five years for your first post?
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 10-07-2013, 09:32 PM   #4
blue694x4
I bought a new tank from classic industies, so I didn't have the donor truck to look at. Wanted to make sure I was missing something before I went to junk yard to find it. If I cant get one I will fabricate it but I'm trying to make this truck appear original by using slightly modified factory mounts and brackets.
As for being slow to post, I suppose I was content to watch. But I really like how this prodject is shaping up and wanted to share it.
Thank you for your input
Old 10-09-2013, 12:37 AM   #5
OldCreek
OldCreek's Avatar
Here's the obligatory, "Where's the pics?", request....
