LS swappers, post your quarter miles times!
I just took my 68 short stepper to the drag strip Friday and was kind of disappointed. Curious what everyone else has ran. If you would, post your engine, trans, mods and weight. I'm sure I am not the only one that is curious about the times people are running.
I'll start. 68 short step 2001 5.3 4l60e Spectre CAI 3.73 gears 28" street tires 3780 lbs with me and a full tank of gas 15.67@83. 75 Posted via Mobile Device |
#2 | |
![]() Join Date: Jul 2012
Re: LS swappers, post your quarter miles times!
Yeah, I was surprised at the weight too.
Boosted Member
11.95 @ 115 in my 69 C-10 LWB.
stock everything 5.3, lifting the heads 4L80E with a 3400 stall yank turbo off of a 3406 Cat on-highway truck engine 3.73 gear with 26" MTs air ride suspension 3950 without me in it It would 60' like a slug, then come alive with a vengance. Hoping to get the blazer to the track this fall some time....but I DO know how it runs from a roll against a 2900 lb turbo LS1 RX7 ![]()
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2023 Ford Explorer ST - Twin Turbskis 2023 Ford F150 RCSB - Whipple Supercharged 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! Last edited by Wasted Income; 10-02-2013 at 04:56 PM. |
I have followed your blazer build, I love it. I plan on going 4l80e and turbo, hopefully next summer. I wanted a 4l80e when I put this truck together but the engine came with the 4l60e, couldn't complain.
I'll let you know when I get it down to the track. can't wait to find out!
68 Long Fleet Stock 2003 6.0/1995 4l80 3.73 gears 28" Street Tires Getting it weighed on Saturday
Will 1968 C10 - Project Texa Go 6.0/4L80e 2003 Mitsubishi Lancer Evolution 2002 Ford Excursion 7.3L 2024 Toyota Sienna |
my last runs were with my 5.3 and a GT2-5 cam and ls6 springs. The rest is stock. I ran a 75 shot of nitrous wet with a wide open switch. Stock 4l60e with vette servo and trailblazer converter.
This combo ran a 13.2 at 102 MPH. I don't have my slips here but my 60 foot times leave alot to be desired. I am also heavy since I have a rear cover. I have not ran since my turbo and changing to a T56. It is much stronger but I know my shifting will hurt. Oh and I can run my AC to and from the track...
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
Last time at the track I went 12.9 at 102 mph. Mods are:
All aluminum 5.7 241 heads with a tiny amount of bowl cleanup done Tiny comp cam does not even chop Stock 2010 camaro exhaust manifolds Stock truck intake Stock truck dbw throttle body early style 3.5 inch intake tube Ls6 maf 3" exhaust from manifolds back 4l60 with a "stalled" stock converter foot brakes to 2200 3.73 gears with 275/65-15 radials 1.97 60 ft 8.3x at 84 I think mph 12.9 at 102 mph Last time on the dyno it made 372 hp 364 tq at the tires. Not too shabby and I still average 19-20 mph mixed driving. Pretty proud of myself as I have built and tuned this all myself.. |
That's moving along for your mods. What are the specs on that "tiny" cam if you don't mind? That's a really good dyno number for a small cam.
his 60 foot times are helping him quite a bit.
Im hoping for some low 10's with the ac on to and from the track...
http://67-72chevytrucks.com/vboard/s...d.php?t=494388 431 big block times, changed to a 6.0 ls with turbo 1.58- 60' 7.18- 1/8th mile@95.18 11.37- 1/4 @115.81 |
Yeah it's a comp cam grind number 54-456-11 specs are .607/.614 219/227 112. It's a nice torq cam but I plan to swap to a slightly larger cam soon. I am also planning a set of headers and edlebrock proflow intake with the hopes of 420+ rwhp. Along with a slightly larger stall I am hopin to break into the 11's na then add a 125-150 shot and nab and mid to low 11 second slip. All while it being my daily driver and knocking down 18-20 mpg.. Hehe
#13 |
1.97 60' isn't bad, but it's not amazing. For what it is, that truck is moving. I ran a 1.86 60' in my TBSS and only pulled down a 13.2.
#14 |
#15 |
6.0 powered square
Too slow
1980 c10 swb 4150 with 210ib driver 6.0 lq9 tsp 228r cam lt header cai intake 2 1/2 exaust 40 series mild tune 4l80e 3600stall nitto nt555r 1.74 60 7.89 @87 12.42 @106 Soon 3" exhaust race bullets, tbss intake ported 90, under drive pulley, stronger tune, and hoosier drag radials 7.7s hopefully then spray to get in the bottom 7s
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
#16 |
Truck and auto performance nut
Have no idea...ran 8's in the 1/8th with a carb and an MSD that wasn't curve optimized...should do better now. Target is "fast"....then "faster"!
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
#17 |
GM ONLY BABY!!!
72 GMC lwb on airride with a/c. Stock 6.0 / 4L65. 3.07 gears, 20" wheels. 3850lbs I think.
60' 2.249 1/8 9.66 mph 74.76 1/4 14.95 mph 91.66
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride ![]() ![]() http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
#18 |
Location: Sunny, Florida, some might call it South Alabama
I'm hoping for 12s when I get home. I never tracked her before I left
Just sold my C10...sad day... Looking for a 1972 Blazer to hopefully fill the hole in my heart. |
#19 |
I know it's an older thread but I just went to the track yesterday and ran my 56 for the first time since completed. It's a stock 5.3 with stock stall and 3.08 gears. The truck weighed in at 3550 lbs. I'm the right lane number 515.
56 GMC BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=368649 69 long bed Chevy turned 67 gmc jimmy roadster: https://67-72chevytrucks.com/vboard/...d.php?t=851167 |
#20 |
GM ONLY BABY!!!
Installing 3.73 gears today in place of the 3.07 s. Hope to make it to the track later this year.
