hillbilly
firewall holes
im trying to figure out what holes are what on this firewall. I know about the ones around the brake and clutch master cylinder. which ones are for the firewall insulation pad? I know some holes above the distributor are for wiring and I would like to move them down and hide them.
-1962 C-10 |
Re: firewall holes
Heres some. I'm sure a few other guys can tell ya what the rest are for. Me I just kinda look at the pictures of originals and go from there.
![]() Heres a decent reference pic. [IMG] ![]()
'62 Chevy K10 |
Re: firewall holes
'62 Chevy K10 |
Re: firewall holes
Mitch =Floyd for the win! Nice reference
hillbilly
Re: firewall holes
which ones are for the push pins to hold the firewall pad on?
-1962 C-10 |
Re: firewall holes
MitchFloyd, I think you have the choke wrong on the first reply... Right on the second under the master cylinder.
Re: firewall holes
I will update and post a correct version. Thanks!
'62 Chevy K10 |
hillbilly
Re: firewall holes
Which ones are forthe firewall pad?
-1962 C-10 |
Re: firewall holes
Re: firewall holes
I think you have the "tail light wiring harness" hole and the ''throttle cable'' hole swapped..
"Sucks to be you" Suxtobu65 ![]() |
#11 | |
Re: firewall holes
![]() EDIT: Here's a better picture. ![]() Last edited by racecougar; 12-12-2013 at 08:09 AM. |
Re: firewall holes
Nice pics for reference....and still has the firewall markings....very cool
There are also differences in the earlier trucks. My 61 has the rear harness picking up under the access plate on the driver side floor board. My 63 has a rear harness that connects on the firewall over the throttle assembly.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
#13 |
Re: firewall holes
Yep, there are all sorts of old markings on this thing (and I was sure to take photos of all the markings before teardown). The truck has been in the family since it left the dealership, and it's sat in the back room of our shop for the past ~25 years, so it was very stock/untouched but also very rusty when we started tearing into it almost one year ago.
I don't know if the hole locations would have changed at all based on which factory the truck was built in, but just in case, this was a St. Louis-built truck. |
#14 |
![]() Join Date: Jun 2006
Re: firewall holes
The oil pressure outlet is where my chock cable comes out on my 65 jimmy.
Custom Painter/Restoration Specialist 1965 GMC 3/4 Ton LB SOLD? 1964 Chevy El Camino in full restoration 1991 Chevy S10 288K+ miles 2nd Owner SOLD 2020 RAM 1500 Warlock |
#15 |
Re: firewall holes
Old thread i know, "unused" on racecougar's truck above on mine is the reverse lights lead, which is separate from tail lights. I believe in 65 i was an option, but standard on 66.
Project "i'm just going to clean up the interior and the engine bay": http://67-72chevytrucks.com/vboard/s...d.php?t=550931 |
#16 |
Moderator
![]() ![]() Join Date: Aug 2011
Re: firewall holes
I was just about to ask this question - Amazing place
#17 | |
Re: firewall holes
Great reference!!! Thanks for for posting!!!
My build link.. http://67-72chevytrucks.com/vboard/s...d.php?t=285353 |
#18 |
Re: firewall holes
My truck had a couple holes in the firewall...seems everybody who bought it decided to run a different CB radio wire into the engine bay. I ended up welding and I am still welding. I will be welding shut the insulation pad holes and using a stick on insulation pad. Trying to make the inside as sealed as possible which means also trying to run as much through as few holes as possible.
#19 |
Re: firewall holes
What a useful posting.
I think I may have a few spare holes in my firewall.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
#20 |
Re: firewall holes
Glad to see it still getting some use!
#21 |
![]() Join Date: Dec 2014
Re: firewall holes
Other than welding the extra holes has anyone find a way to seal them good to prevent heat or air from getting into the cab. the reason im asking its because my firewall has been painted already and never thought about the extra holes being an issue but now im ready to install new firewall insulation and would like to get all holes that im not using covered.
#22 |
Re: firewall holes
Rubber plugs. Plastic ones with dab of caulking? Insulation tape, duct tape, depending on what level of cover or plug .
Lowes has metal,plastic and rubber covers in their special bin in hardware.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
#23 |
Re: firewall holes
That's what I was thinking but also was wondering where to get em. I think I got both questions answered thanks LVphotos
#24 |
![]() Join Date: Apr 2009
Re: firewall holes
Usually your local mom n pop hardware stores have an amazing collection of these. I also use to buy chrome bolts for my choppers there.
- Patrick 1964 GMC pickup lwb ~ My newest build! 1937 Ford Coupe ~ Custom frame, LS1, quickchange 1950 Chevrolet 3100 ~ Bagged (Sold) 1931 Chrysler Roadster ~'32 Ford Frame, Channeled 8" ![]() 1967 Chevelle ~ 454 Triple Black (Sold) 1964 Chevrolet Impala SS (Sold) |
#25 |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Re: firewall holes
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
