10-02-2013, 03:27 PM | #1 |
led lights
i no led lights have been covered before, but who or what brand of the led tail lights or front lights is the best to buy?
10-02-2013, 04:37 PM | #2 |
Re: led lights
I bought a pair of led tail lights, the kind that have the led's in the lens for my 62 step side from Classic Industries and they did not fit inside the cup at all. I am not usually disappointed with there product but his time I was.
10-03-2013, 06:06 PM | #3 |
Re: led lights
any body else buy some led lights? where did you get them and how good were they? thanks
10-06-2013, 03:46 PM | #4 | |
Re: led lights
I'd try & find same for fleetside--my guess would be the 'conversion kits' would be difficult to make fit. HTH, Sam |
10-09-2013, 02:57 AM | #5 |
Re: led lights
10-09-2013, 03:37 AM | #6 |
Re: led lights
let me no how they work out for you. also hows the quality of them. thanks
10-09-2013, 08:00 AM | #7 |
Chevy addict
Re: led lights
United Pacific are the best, they fit good and have the most leds of any manufacturer. I sell them and use them in my vehicles.
10-09-2013, 08:10 PM | #8 |
Who Me?
Re: led lights
I bought some from ebay a long time ago and so far they have worked great.. I don't know the brand, im sure they were an off brand. All the LEDs are flush looking out of the lens.. I have had them there for over a year at least with no issues.
Steve 1997 Tahoe LT 4D 2WD (DD) 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
10-31-2013, 07:26 PM | #9 |
Re: led lights
I bought mine from LMC it fitted good and work well
11-01-2013, 09:35 AM | #10 |
Re: led lights
If you just want to make your running lights and turn signals brighter, solder a ground wire to the housing of the light housing, then run a ground wire back to the frame of the truck (or a grounding block) make sure you clean the corrosion from the bulb housing, you will now have bright running/turn signals and it will not cost much. Kieth
11-21-2013, 02:09 AM | #11 |
Re: led lights
I finally picked up my United Pacific LED tail lights.
11-21-2013, 02:12 AM | #12 |
Re: led lights
Before and after.
11-21-2013, 02:22 AM | #13 |
Re: led lights
I ran into a problem with getting the lights to ground, so I soldered a ground wire from the metal housing and attached it to a bed bolt. That solved it. The stock thermal flasher doesn't work with LEDs, so I've ordered a 'no load' flasher to cure that.
11-21-2013, 02:39 AM | #14 |
Re: led lights
I changed my seal beam lamps to 6024's with Hella H4 bulbs. The lamps have clear LED's that I've wired as turn signals, since my stockers no longer exist. I used slightly longer screws to attach the retainer rings.
11-21-2013, 09:14 AM | #15 |
1965 Chevy C10, 2005 4.8L/4l60
Re: led lights
Heck yes! I like that Lo Blu62!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
11-21-2013, 01:19 PM | #16 |
Re: led lights
we need some more pic's--------nice from what i see.
1961 chevy K10 my build is------------61K10 build |
11-21-2013, 05:32 PM | #17 |
Re: led lights
A little off subject but I tried to install led front turn signal and it made it so that all my tun signals on both sides blinked when I turned on my turn signal. I have the new type of blinker so that this is not supposed to happen. Any thoughts?
11-21-2013, 06:51 PM | #18 |
Re: led lights
them tail lights made a huge difference but they aint got no bowtie on em.
1964 BBC 402 4x4 |
11-21-2013, 07:18 PM | #19 |
Re: led lights
forestb check grounding
11-21-2013, 11:56 PM | #20 |
Re: led lights
The wiring is all stock. The headlights are 55/65 watts, so the stock wiring and switch should be fine. Grounding is the biggest issue with LEDs. Make sure you have good grounding with each circuit. Add your own ground, if necessary. A 'no load' flasher is necessary because of the low amp draw of LEDs. I chose, at the recommendation of another member, a reverse polarity flasher with it's own ground wire to solve the problem. Will know in a couple of weeks if it works.
11-22-2013, 12:33 AM | #21 | |
Re: led lights
MY 65 C20 BUILD http://67-72chevytrucks.com/vboard/s...d.php?t=483346 ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ |
11-22-2013, 01:08 AM | #22 |
Re: led lights
11-22-2013, 01:11 AM | #23 |
Re: led lights
Here's a link:
7" Round H6024 Sealed Beam Replacement Chrome... And the price has dropped. They don't have the DOT stamp on them, but make a nice pattern at nite. You can chose between white and amber LED halo lights. |
11-22-2013, 01:30 AM | #24 |
Re: led lights
I don't know why the link is not working. Search "7 inch round halo LED headlight" on Amazon and they should come up.
11-22-2013, 01:34 AM | #25 | |
60-66 Nut
Re: led lights
Link doesn't work for me......
Edit: but now it does if I click on the quoted post \/ \/ Quote:
