ecm programming?
I've been searching, and searching, and searching. Is there a software program I can purchase that allows me to program my ls2 ecm myself, like to get rid of the emmisions monitor and disable the vats system? I am a GM technician and I can program modules all day at work, but I cannot custom program anything. I really appreciate any help you guy's can offer. Thank you
A sweet 2000 Deville..... |
Re: ecm programming?
I could also use recommendations on mail in ecm programming places as well. Thank you
meowMEOWmeowMEOW
Mail order tunes are useful, but only the basic needs. They will never offer the same performsnce gains or driveability as a dyno and street tune, because there are just too many factors that they csnt account for. I always recommend finding a respected local tuner to do a dyno tune...
Now on the DIY front, hp tuners is probably the best option in terms of gm efi tuning. It does have a bit of a learning curve, but it has a big support community and you can donwload base tunes etc. For some of the basics like emissions deletes , its really just clicking boxes. The benefit is you have thr full gamut of controls at your fingertips, which is nice for thrings like the tranny feel and tire size chsnges. Posted via Mobile Device
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
How about LS2 Edit
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
meowMEOWmeowMEOW
Ummmm...that thing is about 3 grand, and cant do anything pre 05 which leaves out many ls engines.
Seems hard to justify that when hpt and even efi live are cheaper and at first glance, even more capable. Tho i will admit the installer package for hpt isnt "cheap" either. Posted via Mobile Device
Weird.
I've seen LS1 edit and LS2 edit advertised for around $400. It's probably for a single license. I never used either.
Hp tuners hands down! For $500 you can get what you need minus a wideband to tune your setup perfectly!
Can I delete the vats system with the hp tuner program? I got a quote from a very respectable ls swap shop in AZ for $310 to program the ecm to my needs. They will even reprogram it anytime I need them to for free after that. The only problem is I have to ship it to them every time I need something done. I live in Reno, and believe it or not, there really is not any place I can find that can program them here. I'm going to call around again tommorow to try the last few places I can think of.
![]() Join Date: Apr 2005
Sorta off topic, but computer tuning related, should I be able to get get data out off of the Can signal even though I haven't had my computer programmed yet? I'm trying to get my gauges to work, but so far no communication.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#11 | |
meowMEOWmeowMEOW
Hart - you HAD to go and f*** with the CANbus system didn't you ![]() What are you using to look for an output from it? I would think that a stock computer would retain whatever CAN stuff was hard programmed into it....unless the pcm is actually BLANK, like nothing at all.
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
OP, I would try to find an experienced tuner close to you, one that would dyno your swap IF you have made any power adds, meaning Cam etc. If you are just stock with headers and want VATs and rear O2's removed, then I would not hesitate to get a mail order from some one like Nelson Performance, they will mail you an ECM that has been tuned and you send yours back to them. They do this because if their tune isnt what you want, then you can throw your old ECM in and it will run ( after the first flash that is) I did this and they have been very helpful.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
#13 |
For about the price of the HP tuner you could pick up a Megasquirt system and wiring harness, and use their package to tune your car. I'm about to start that process for my 66 with a TPI.
It'll have a bit steeper learning curve than HP Tuners, but their software (I hear) is pretty expansible, and also offers some auto-tuning functionality when you use a wideband O2 sensor. They say it works pretty well to get the DD tuning dialed in. You set your desired AFRs and it modifies the fueling to meet those commanded AFR tables. |
#14 |
meowMEOWmeowMEOW
MS is great but its taking the long way around the problem, unless the vehicles has a specific need to do things like driver abnormal amounts of enriching injectors, control COP spark on a non-equipped vehicle, all sorts of goofy stuff. I believe there is a newer member on here who is actually pretty well versed in this topic. I want to say his name is Matt C or something like that, saw some stuff he did on an MS website. It makes sense for your tpi but i fee like its going out of the way for an ls.
GM Spent millions of dollars developing a pretty dang good ecm, in regards to something that is functional yet actually pretty simple to work with.
#15 |
Yes, that would be me... and for my truck, yes, the fact that I'm putting an MS3 on a stock 4.8 is overkill. It does make sense for me in a wider context, though: I work for one of the biggest MegaSquirt distributors, so this is kind of an exercise to better support customers who are running MegaSquirt on these motors. (Unfortunately, I wasn't able to convince the boss that paying for a blower kit would let us support LS customers even better.
Matt Cramer 1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD 4.8 LS build thread |
#16 | |
#17 | |
I don't know why I keep thinking its in AZ, but the quote I got for$310 was from S&P. They keep a record of the ECM program and will reprogram for free anytime after the initial payment. There are no local shops I've found around here that offer a dyno tune service. Kind of weird when you consider the fact that Reno hosts the one of the biggest annual car show in the nation, and is home to one of the biggest performance auto parts suppliers..... I got a quote from a local that will program the ECM for me at $250, but I can't find any info on the guy. The ECM is probably going to go to S&P for the initial tune, then we may drive the truck to Sacramento for a dyno tune.
#18 |
Boosted Member
I own the commercial version of EFI Live, and have used it quite extensively in the past. To me, it is far more user friendly than HP Tuners...I fiddled around with the tune on a buddy's turbo LS and kept getting lost in the GUI in HPT.
That said, I'm also a megasquirt user...and if the OP has never done any custom tuning, and if it's a basic, stock engine setup, you'd be better served with a reflashed stock ECU.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
#19 |
![]() Join Date: Jul 2013
EFILIVE. It is the bomb. You being a GM Tech, you will like the similarity to the TECH2 for troubleshooting. Plus you get infinite tweeking ability of the PCM and live telemetry and data recording.
EFILIVE was developed by Rouge/hotrodder group of Holden down-under. Its $900.... pricey, but if you can find a few friends that want a tune you can pay for it pretty quick. Plus there is a mountain of tech info and user developed tunes to fit most any need available for free.
Mark Jesus is the Way! 2003 2500HD CCLB Duramax/Ali (Clifford) 2014 2SS/RS black on black Camaro (Betty) 2006 Pontiac SOLSTICE silver/black (Lula-Bell) 1970 C/10 Short Wide (Peggy) 1964 C/10 Short Step (Hambone) RIP Jimmy Hamilton Thank you for the trucks |
#20 |
Yep, that's why I said the MS3 is overkill for my particular setup - it's just a stock motor with a different exhaust, so really the only tuning it would need would be removing anti-theft systems and some emissions monitors. An install that needed more involved tuning could be a different story. The cost is pretty close between MegaSquirt and many of the stock ECU tuning solutions, so it's mostly a trade-off between tuning flexibility vs the advantage of starting with exact factory maps.
#21 | |
Boosted Member
