Old 10-03-2013, 12:36 AM   #1
c10 custom
700 r4 transmission
hi guys i own a 1968 chev truck shortbox and i want to install a 700 r4 transmission into it what do i need for this swap i also want to change to a one piece driveshaft any advice on this would be great thank you
c10 custom is offline   Reply With Quote
Old 10-03-2013, 01:25 AM   #2
Z10
Z10's Avatar
Re: 700 r4 transmission
Here's the list:
1. 700R4 transmission
2.
3.
4.
5.
6.
7.
8.
9.
10.
I'll let others fill the rest of the list out.
Sorry, I couldn't resist.
I'm actually about to start the swap, when I finish, I'll try and post pics etc.
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
Old 10-03-2013, 03:41 AM   #3
mrsiege
mrsiege's Avatar
that is mean lol
mrsiege is offline   Reply With Quote
Old 10-03-2013, 05:11 AM   #4
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
What trans is in it now?
More parts are needed if you dont already have an auto,(cooler, trans lines) if you have a turbo 350, the yoke will work on the 700r4, if you have a 400, you will need a new yoke.
1.You will need to move the trans crossmember back for the 700R4
2.You will need need torque conv bolts (Metric)
3.You will need to figure out how the OD/Lockup circuit will work
4.You will need to fiigure out how your speedo will adapt (a lot of 700's are electric speedo's, you can change it over to manual, google PATC in Louisiana, they have all the parts)
5.You will have to change the shift linkage so you can manually engage all the gears (if you have auto now, the set up will work, but not for all gears)
6.Shift indicator for column, if you want it to look right.
7.I have just done two of these swaps....
8.Drive shaft should be fine as long as your pinion angles are ok.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 10-03-2013, 04:39 PM   #5
Budda-Boom
If buying used...early Turbo 700s, 1982-85 were trouble-prone. Not very beefy inside...MAJOR upgrade in '86 made them almost bulletproof.
Be sure you get one from an '86-up Chevy.
Budda-Boom is offline   Reply With Quote
Old 10-03-2013, 06:17 PM   #6
Z10
Z10's Avatar
Agree. I purchased a GM certified 700R4 from my local Buick/Cadillac dealer. I asked and received one that was a direct replacement for a 1990 Corvette.
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 10-03-2013, 07:57 PM   #7
Bigdav160
Bigdav160's Avatar
There were many changes to the 700R4 through the years including the first couple. The forward sprag was improved. The input -3/4 clutch line up changed. In 1986 had a larger input shaft and a couple more vanes in the pump. 1987 was the year hydromatic did the 700R4 upgrade. They added a forward accumulator circuit to soften the shift to drive. More vanes were added to the pump. Accumulator lineup changed slightly.
Unless your building 300hp + any 700$r can be built to be dependable and work well.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 10-03-2013, 08:14 PM   #8
bovey
bovey's Avatar
I did this swap in 2002 on my 350 in my '71 GMC. Super easy.
Main points you need to remember.
You want a later 700R4 - '86 or '87. Ideally, you want an early 90s (90,91,92 - I think) out of a Camaro, Trans Am. At this point, I'll assume they all need to be rebuilt.
FYI - I had my done to the fullest extent in 2002. I put 100,000 hard miles on it and thought it was baked and was going to sell it as a core. Ended up testing in another car and it worked perfect - turned out my 350 needed the rebuild...
700-R4s are mechanical. in '93 they changed to 4L60s which are the same, but electric, I think you need a module to make the shift.
Torque converters are not made equally. Research it do death, or you'll hate it.
TV cable adjustment is very important AND super easy - yet many screw it up.
Finally, don't let people tell you these transmission are not tough. They are, you just need to do it right. My shop has guys running 9s all day on 700-R4, I have put one behind a 526 cid in a 4600lb car and it does fine too.
I also reco 3:73 gears. Great fun. Great milage.
There are loads and loads of tech articles out there. Google will be your best friend.
It's a great swap. Enjoy.
bovey
bovey is offline   Reply With Quote
Old 10-03-2013, 08:50 PM   #9
GMC Canuck
TV cable adjustment was mentioned but you will need the cable and brackets to attach to the carb. Lokar makes a nice one with brackets.
GMC Canuck is offline   Reply With Quote
Old 10-03-2013, 08:59 PM   #10
calvin78612
calvin78612's Avatar
Google trushift transmission bracket. It will lead to Bowler trans.in Lawrenceville, Illinois. Everything you need as far as brackets and TV cable. $229.00.
84 step side
87 swb
calvin78612 is offline   Reply With Quote
