Old 10-03-2013, 03:19 PM   #1
Procurement_man
Procurement_man's Avatar
Power vs Manual intermediate shaft
I’m converting from manual steering to power and would like to know if the intermediate shaft is the same or do I need to get one from a power truck. My new power steering box has a 13/16” shaft and that made me start thinking, the manual box had a ¾” shaft and they may be different.
I’m still looking for a new rag joint so I can’t mock things up until all the parts have been located.
"God will often give you more than you can handle so you can learn to depend on him rather than on yourself" ...Craig Groeschel
Procurement_man is offline   Reply With Quote
Old 10-03-2013, 05:13 PM   #2
jimmydean
jimmydean's Avatar
Re: Power vs Manual intermediate shaft
When I converted my '69 to power (from a '75), I just dropped it in (with pitman arm attached) without changing anything.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 10-03-2013, 06:40 PM   #3
Robznob11
Robznob11's Avatar
The splines on the man are 3/4 x 32 so you will need the bottom section of the joint they ca n be found on line and at most parts stores in the help section
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
