cheap engine cleanout
I was wondering, the other day I saw a video of someone pouring water down the carbeurator to clean out carbon deposits, is this safe? I know you can run seafoam through the carb via vacuum line but is water safe to do this with?
Austin 2005 GMC Sierra 1500 4X4 4.8l V8 (Wrecked) 2003 Chevy 1500 standard cab short bed 4x4 w/ 5.3l |
Re: cheap engine cleanout
I use to work at a dodge dealership and they would do the same thing with automatic trans fluid. They would hold the throttle 3/4 way down and someone would start pouring. Needless to say it would smoke the whole city block up. Whether it did any good idk.
1980 Malibu Classic 2 dr coupe 1964 Impala SS 4 speed 1968 GMC (major project) grandpa bought new 1969 Chevrolet C-10 Shortbed Fleetside 2008 GMC Canyon (daily driver) |
![]() Join Date: Jul 2012
You can use water but it does not work as well as seafoam. Plus there is not advantage to letting it soak like there is with seafoam.
1971 Chevy C10 Cheyenne (sold for Mazda) 1963 Chevy Corvair Pro-Touring Project 2012 Mazda 3 i Sport sedan http://www.dracoautodesigns.com/ |
This works well on my son's go kart. After a while the valves start sticking. Pour in some ATF while it is running gets them lubed up again.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
![]() Join Date: Aug 2010
Just a reminder water DOES NOT COMPRESS!!!! You will hydraulic the rod it you add too much. Found out the hard way racing boats and when it flipped over water got in the carb bye bye rod!
Marty |
![]() Join Date: Jul 2013
The water does work, but is DANGEROUS for your motor.
SeaFoam is a way better alternative. Back in the day engines would carbon up, but now days the gas has so many detergents and ethanol that carbon is not and issue like 20+ years ago.
Mark Jesus is the Way! 2003 2500HD CCLB Duramax/Ali (Clifford) 2014 2SS/RS black on black Camaro (Betty) 2006 Pontiac SOLSTICE silver/black (Lula-Bell) 1970 C/10 Short Wide (Peggy) 1964 C/10 Short Step (Hambone) RIP Jimmy Hamilton Thank you for the trucks |
Cluster King
![]() Join Date: Nov 2012
Well what ever you use you need to use in moderation or hydraulicing may be an issue and that does tend to be hard on connecting rods. Good old fashion prestone works very well. Have you ever seen the top of a piston that had a coolant leak on it? It does a great job removing carbon deposits.
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com I am also a dealer for Counterpart for gauge cluster parts only. Also see my facebook page, CG&C |
#8 | |
Fuzzy |
Seafom works great. I used it on my wifes 2001 Mustang when the V6 would start to knock when hill climbing. Run a bottle through the PCV line while raising the RPM. Smoke the neighborhood and highway all the way into town. But no more knocking from carbon buildup.
Where's my beer?
I remember my buddies dad who was a Chrysler mechanic back in the 60's talking about dribbling water down the carbs on a cross ram 413. He said he rigged up something so it just barely dripped so of course it wouldn't hurt the engine, but instead cleaned it. I"ve used Seafoam myself with noticeable results.
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam. 79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam. '03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great '08 Tahoe LTZ 4x4 155K |
![]() Join Date: Apr 2013
It does work, I've done both water and ATF, IN MODERATION, don't just dump it down the carb.
Use a spray bottle and just mist it into the intake. It's an old racers trick back in the 50's -60's, some even made a water injector for going down the track.
1972 Chevrolet Cheyenne LB 1/2 ton finished restoration/rebuild 1995 350 throttle body FI, 4L6E (running on modified GM wiring harness) 3.08 posi rearend, factory A/C on 134A, p/s, p/b, late 70's power windows and locks and cruise, speakers in the dash + 6x9's behind the seat, factory tilt, 40 gallon fuel tank in the bed with integrated tool box, air assist bags on the rearend, sway bar up front and much more. 1972 chevrolet SNB finished 2002, 350 TB FI, TH400, factory A/C, p/b, p/s, (FOR SALE) 1969 Chevrolet 1 ton in work, home made PTO dump bed extended frame, 350 CI , 1972 Chevrolet 3/4 ton suburban future project 1972 Chevrolet 3/4 ton p/u maybe a project one day 1966 Toyota Landcruiser my playtoy |
If the goal is to remove carbon deposits you want to use something that will both dissolve the deposit and then burn. Water is a poor choice. And as others have said it cannot be compressed, so use too much and it's goodbye rods.
Best to stick with something like seafoam |
#13 |
Another way to do the ATF additive is to pour a quart or two into the fuel tank before fill-up.
I've been doing this on my gas burners for years. It's a cheap fuel additive and cleaner.
