Old 10-04-2013, 01:21 PM   #1
Brad54
Brad54's Avatar
'60-'62 Disc Brake Spindles: recommendations?
Who's disc brake spindles do you guys recommend for '60-'62 trucks?
I'm finally going to rebuild the whole front suspension, and I'm going to upgrade to discs at the same time so I can tow with the truck.
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 10-04-2013, 01:37 PM   #2
doobiebro
doobiebro's Avatar
Re: '60-'62 Disc Brake Spindles: recommendations?
CPP and going strong 6 years already...
CURRENT & PAST CHEVY TRUCKS
60 C-10 Apache short step side
62 C-10 short step side
66 GMC Long bed fleet side 305 V-6
77 C-20 Custom Deluxe (Blue Goose)
doobiebro is offline   Reply With Quote
Old 10-04-2013, 08:13 PM   #3
verdell
verdell's Avatar
I went with CPP and have been running them since '03.
Mine were actually made by Western Chassis too so maybe
you can skip the middle man. Very easy install and stops on a dime...
verdell is offline   Reply With Quote
Old 10-05-2013, 01:44 AM   #4
Brad54
Brad54's Avatar
Any issues with them moving the wheel outboard? I've read that's a problem with some spindles, but not others.
-Brad
Old 10-05-2013, 02:15 AM   #5
verdell
verdell's Avatar
I think my brother who owns a 65 and another friend
of mine with a 64 ran into that issue but my dropped
spindles from Western Chassis were perfect. I'm not
sure what kind those guys have..
Old 10-05-2013, 05:24 AM   #6
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
From my experience on my 65 riding on a 62 frame with torsion bars, the regular drop spindles from Cpp will move your wheels out if you are going from drums, but very little.
Supposedly, the Cpp Modular drop spindles do not move your wheels out at all.
If you do buy Cpp, look at Summit. They had the best prices, and let me return my for a full refund - no questions asked.
I had to return mine because they wouldn't work with my 15" wheels.
66 C20 Service Truck:
Old 10-05-2013, 12:50 PM   #7
doobiebro
doobiebro's Avatar
-Brad
Not at all with mine especially since my front end is lowered around 6 inches. Just keep in mind if you are using the stock rim they will not work for the disc brake..
Old 10-06-2013, 11:40 PM   #8
Brad54
Brad54's Avatar
I'll be using an old set of 5-slots (6-lug).
I really don't know what the stock ride height is supposed to be. I've ranked my torsion bars down pretty far, but don't seem to bottom out frequently. There's a couple threads left on the big t-bar adjuster bolts.
I want the drop spindles so I can put my stock suspension geometry back... or as close to it as is reasonable.
I'd also like to be able to use stock-length shock absorbers too. I've gone through the shock company catalogs and there isn't one with the same mounting eyes and the shorter length required.
-Brad
Old 10-07-2013, 08:46 PM   #9
Brad54
Brad54's Avatar
Does anybody have any experience with the spindles from LMC?
Their site says they move things in 3/4-inch to retain the factory track width and fender clearance.
-Brad
Old 10-14-2013, 12:10 AM   #10
Brad54
Brad54's Avatar
-Brad
Anybody?
Trying to figure out the difference between the ones from LMC and CCP (and Western)
-Brad
